How do i change my boot sequence in my phoenix bios setup utility? computer wont go into windows so im trying to get it started o9ff the cd rom?
Dear Hoby2003,
Do you already have a solution for your problem?
Posted on Oct 04, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
My Dell Windows 7 laptop won't boot?
Press the Delete key during start up, to enter its bios settings window. At boot sequence selection, select CD ROM as first boot device, Hard disc to second boot device, and deselect all other boot devices. Means, there should be only CD ROM and Hard disc as boot devices, as said above, in sequence. Select 'Save and reboot' at the bios option, the computer will restart with hard disc; provided there is no CD at CD ROM. Gopakumar Gopalan Google
May 10, 2014 | Dell Computers & Internet
NEC laptop stuck in Phoenix BIOS Setup Utility
While in the BIOS setup utility, go through the tabs/menus looking for BOOT sequence. Configure the laptop to boot from CD-Drive before any other drive. Have the installation CD in drive.Save the changes made to the BIOS configuration, and exit the BIOS. Reboot.
If the installation medium itself does not have a problem, you should be able to boot from it and have the opportunity to install the operating system.
Jan 29, 2014 | NEC Computers & Internet
What is phoenix bios setup utility
its where you would change settings to affect your computer, it will show computer temperature.
allow you to tweak cpu settings, to overclock etc.
change boot sequence so if you wanted to boot off a cd, usb or hard drive and what order etc. if thats any help
Jun 17, 2012 | Dell Inspiron Mini 10 Notebook
Boot sequence for emachine M6811
As SOON as you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You may hear beeps. This is a Stuck Key Error Beep. (Or beeps)
Ignore the beeps.
You will now be in the BIOS Setup utility.
The BIOS program is made by Phoenix.
It is Version NSF03.P0
Release date - 07/28/2004
http://www.notebookreview.com/default.asp?newsID=2170#specs
Scroll the page down a little, until you come to the bold heading -
EMachines Desktop Replacement Notebook Specs
Scroll down until you see the sub-heading - Detailed specs
Left-click on - Click here to See appendix for detailed specs
Now look under the bold heading - DMI, and [ BIOS ]
When you are in the BIOS Setup utility, you CANNOT use your mouse
anymore. You have to use your Keyboard.
At the top of the BIOS Setup utility you will see headings;
Main, Advanced, Security, Power, Boot, and Exit.
The BIOS Setup utility automatically opens to the Main screen.
Use the Right Arrow key, and stop on the - Boot - tab
What is listed is a Boot Order.
In the list of the Boot Order are Boot Devices.
What is at the TOP is the first boot device the laptop will boot from.
Should be;
1) CD-ROM Drive
2) Removable Devices
3) Hard Drive
4) Network
Having CD-ROM Drive at the top allows you to install a different Operating System, that the laptop did not have from the factory.
ALSO; Windows DOES NOT like to be written over, with a lesser operating system, or the SAME version of operating system.
Examples;
Trying to install Windows 98SE, on a Windows computer that has Windows XP on it.
Trying to install Windows XP, on a Windows computer that has Windows XP already on it.
Using CD-ROM Drive as the first boot device, will allow you to install what you wish.
[ Doesn't work for installing Windows XP over Windows Vista. There is a special procedure ]
If I haven't answered your question, or you have additional questions, please post in a Comment.
Regards,
joecoolvette
May 04, 2012 | eMachines M6811 Notebook
My pc400 will not detect hard drive while in clean window install mode. All primary and secondary are set to auto detect. Boot sequence set to cd while installing from cd rom
You can change the pata cable ,if you have a spare.or fit the cable again.
Follow the link.set for boot priority.
http://www.windowsreinstall.com/articles/bios/
Phoenix BIOS setup and help
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Or you can setup bios "load fail save default"na d pers F10>hit
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
How i can boot from cd
  • Save the setting.
Mar 19, 2010 | ASUS P4B266-C (P4B266-C WA) Motherboard
Had new hard drive put in at Best Buy and now the computer won't turn on. The start up light comes n and the fan starts but the hard drives never boot up. Can't get their store to look at problem so I'm...
they must have put it fully factory, you need to get your cd to start up before the hard drive does so you can use windows utility on to format and partition it , you may need to go into the setup (bios) and change the boot sequence to cd/dvd rom before the hard drive and run windows setup utility to install the OS on your new harddrive
Apr 12, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Unable to Acces BIOS on IBM Netvista 607931u w/ Phoenix ROM BIOS
When the IBM Setup Utility program prompt is displayed, quickly press F1.
The prompt is displayed for only a short time.
if you dont see the prompt, tap F1 repeatedly as the computer starts. If it says "starting windows" you've let it go too far and will have to restart again and repeat the process to get into the bios
REGARDS..
Apr 09, 2009 | IBM NetVista PC Desktop
Computers & Internet Logo
117 people viewed this question
Alun Cox
David Payne
David Payne
