I have ordered a Kenmore washer 29622. I want to be able to use HOT water in a full load. Will this washer do that?
    President:
  • 1,937 Answers
See the following site for installation and operating manuals for these washers.
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Residential%20Washers?query=29622
Posted on Aug 04, 2010
I have a kenmore elite. My softener compartment and occasionally the soap compartment is full of water after a load.
Fabric softeners can coagulate and clog hose. Try pouring hot water into compartment, with washer empty, to clear hose.
Jan 03, 2017 | Kenmore Washing Machines
Any way to lower the required hot water temperature? My hot water heater is set to a low temp and the Washer keeps stopping and giving a F05 error.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
Oct 30, 2012 | Kenmore Elite 45986 Front Load Washer
My Washer is only filling with hot water and cannot complete the rinse cycle because hot water is not an option.
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. Since nearly all washers use cold water only during the rinse cycles, you are correct, the washer will not complete a full cycle. You will need to replace the inlet valve. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
Hot water is filling up washer very slow
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Apr 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
