If your air blower does not run for more than about 3 minutes then you may have a bad motor.
Once it shuts down it should come back on in about 10 minutes after it cools down.
Every motor has a thermal protection built into it to prevent the motor from burning up.
If this is the situation then you will need a new motor.
some tubs have a powered blower (you can hear it) or some tubs have a venturi suction bubbler system, you will have have to pop open service cover to look to see what kind you have, venturi type most of the time are turned off or down to far and don't produce bubbles (twist knobs) powered blowers sometimes have hoses pop off there fittings
You can order bubble tubes and damaged front plastics from Deer Park Dist (618) 427-3761. Once you get the parts, remove the back of the unit. You will be able to see all the screws which hold on the front plastics. Removing the screws and the plastics to get easy access to the bubble tubes. A long screwdirver is helpful. The magnets in the speakers will grab the screws and the screwdriver from you.
