Question about HP LaserJet P4015 Printer
Can't reset maintenance count on laserjet p4015
  • 48 Answers
Reset the maintenance-kit counter 1. Turn the product power off and then on. 2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds. 3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT. 4. Press OK to reset the maintenance-kit counter.
Posted on Aug 31, 2010
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
HOW TO RESET PAGE COUNT TO ZERO
Hi i am PARTYAB.COM from iran.
It is simple.
1.power off hp 2055dn
2. While pressing and hold Down and Cancel Key power on printer
3.you will see permanent storage init. On the panel
4.after that you can set and change language and location like when buy a new printer .... set it.
5.and now you have got a printer with zero count page printed
6. Ok now you can tell lie to others that this a new printer an sell it more price.
Otherwise What's the reason you want to change count page printed? :)
Aug 08, 2014 | HP Laserjet Printer P2035 P2055 Laser...
Help my hp laserjet 5000 printer is showing 50.4 fuser error
follow the following instructions
The Short Cut Method"
1. Turn the printer off.
2. Hold down the [Item-] and [Value-] keys.
3. Now turn the printer on.
4. Wait for RESET MAINTENANCE COUNT to be displayed and then release both keys.
NOTE: Some versions of the LaserJet 5000 will NOT have their maintenance count reset by following the preceding "short cut" method. This is due to the many different formatter board revisions. If the short cut method doesn't reset the maintenance count then you will need to go into Service Mode to manually reset the maintenance count.
Jul 30, 2014 | HP LaserJet 5000 Printer
77D4 953864 PRINTER ERROR
This is a communication error. Make sure there isn't anything in the print que. If there is try deleting it. Unhook the printer from the network or computer and try and powercycle the printer. If that doesn't work try a cold reset. Turn the printer on and once the memory starts to count up press and hold the check button until the three lights light up and release then scroll down and hit the check mark on cold reset and see if the printer comes to ready. This will reset the IP address if the printer has one
Mar 24, 2014 | HP LaserJet P4015 Printer
P4015n maintenance kit replacement
This maintenance kit consists of a fuser, pick up rollers, transfer rollers. On this model you can also reset the maintenance count by entering the service mode and sometimes by scrolling down to the config menu until you see resets.
Mar 04, 2013 | HP LaserJet P4015N Printer
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
I have an Hp laserjet 4200 printer and would like to know what regular maintenance I should be undertaking,and parts checking.
A maintenance kit(feed rollers, transfer roller, fuser) should be installed every 200,000 pages.
If you look at the "configuration" page, left column about 1/4 of the way down you will get the page count and when the last kit was installed.
The kit will come with instructions for installation and resetting the page count.
It is an easy printer to maintain.
Feb 08, 2011 | HP LaserJet 4200n Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
Error 49.00ff
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off
1- Turn the Machine on.
2- Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
3- Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced.
Oct 21, 2010 | HP LaserJet P4015N Printer
HP LaserJet P4015 Printer Logo
1,628 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
