Question about Lenovo 3000 G530 Notebook
We ordered a replacement keyboard for a Lenovo G530 laptop. The computer wouldn't run with the built in keyboard plugged in. While waiting for the new keyboard I restored the system using the recovery disks and a USB keyboard. Now the replacement keyboard is here and installed but Vista sees the keyboard as a standard PS/2 keyboard and the fn keys won't work. What's worse is numlock is on. Is there any way to tell the system or Vista that this is NOT a standard keyboard. I haven't had any luck finding drivers for it.
  • 551 Answers
SOURCE: numlock problem in HP DV9000
why need to press numlock when it has already a numeric numbers above? when pressing numlock on a laptop it will turn the letters to number because you lock the it. now to go back on the letters you have to press again the numlock key.
Posted on Apr 08, 2010
ruwidperd372
  • 279 Answers
SOURCE: My Lenovo G530 laptop does not acept sound drivers
On Win XP , you need to install Microsoft UAA before installing sound driver. Get the right drivers according to your operating system.
http://www-307.ibm.com/pc/support/site.wss/CONS-SUPPRT.html
Posted on Apr 10, 2010
  • 162 Answers
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
Posted on Jun 02, 2010
  • 8909 Answers
SOURCE: where do i get a recovery cd for lenovo 3000 g530
There are a number od web sites offering the service but you don't explain the OS used.
I take a guess at this one.
http://recovery-cd.com/system/Lenovo/Lenovo3000/Lenovo-3000-G530-4151-XP-Recovery-CD-421946.html
There are XP, Vista etc. etc.
Hope this gets you started again.
Posted on Dec 13, 2010
carloadrian
  • 571 Answers
SOURCE: My Lenovo Laptop 3000 G530 touch pad of mouse is
Thank you for posting your problem in fixya. I am very happy to assist you. I am providing you with a link so that you will be directed to a guide on how to fix this problem. Click on the link below:
http://www.fixya.com/support/r8113144-enable_touchpad_in_laptop
I hope this helps.
Thank you for using fixya,
carloadrian
Posted on Feb 03, 2011
Lenovo 3000 g530 4151 battery is not charging,give the solution
When you connect and disconnect the AC adapter, do you hear a beep? If you do not hear a beep, check the AC adapter for the following.
1. Check that you have power at the plug in the wall. Don't laugh, this happens.
2. Check the cable that plugs in the wall is fully plugged in the adapter. It needs to be fully seated.
3. Check the cable that plugs into the computer. Make sure is not damaged from running over with chairs, etc. or maybe someone tripped on the cord and damaged it.
4. Measure the voltage at the plug with it disconnected from the computer. It should be the same voltage as marked on the sticker. If you are not getting the correct voltage change the adapter.
5. If you are getting the correct voltage, you may have a bad battery, or a bad motherboard. Replace in that order.
Feb 04, 2014 | Lenovo 3000 G530 4151X3U Laptop Charger...
Atter mac os has been installed in the pc,it is showing as operating system not found in my lenovo g530 laptop
The mac operational system is designed for apple computers only, It will only recognize the drivers in the apple product line. The pc computers have a different configuration and will not except this software.
May 20, 2012 | Lenovo 3000 G530 (4151X3U) PC Notebook
I have lenovo 3000 G530 laptop which turns off automatically after 15 sec when turned on. All the lights are blinking when restarted. But again turns off itself.
The problem is most likely caused by the DC jack in the laptop, "common problem" the computer must be dismantled down to the motherboad level and the plug resolded on the flip side of the board, also a can of compressed air will do wonders cleaning the cooling fan and heatsink and open port area's.
Apr 29, 2012 | Lenovo 3000 G530 PC Notebook
MY LENOVO LAPTOP WONT SHUT DOWN
push and hold down the power button.then unplug power cord and remove battery.wait a few min then but battery back and plug it in and restart..
Mar 24, 2012 | Lenovo G530, G550, G560...
PRAKASH SINHA I HAVE A PIRCHASED LENOVO LAPTOP 3000 G530 IT WAS ALREADY INSTALL VISTA.BUT MY WEB CAMERA DO NOT WORKING.
here's the Lenovo 3000 G530 Camera Driver.
http://uploading.com/files/get/D47VIXMU/
the click free download wait for it to be available then download it. and install it.
Feb 18, 2010 | Lenovo 3000 G530 Notebook
Lenovo built in microphone stopped working
I had the same issue with my G530. I have boosted the microphone to maximum from Control Panel - Sound - Recording - Level. It helped. You may try it too.
Jan 18, 2010 | Lenovo 3000 G530 Notebook
How to access the inside of my laptop to clean it
Hi!
This website will show you, step-by-step how to access the inside of your Lenovo 3000 laptop.
http://www.insidemylaptop.com/remove-keyboard-replace-launch-board-lenovo-3000-laptop/
Should be exaclty what you're looking for. Obviously be carefull pulling it apart, laptops are built with many small components that if damaged/displaced can be a pain in the **** to track down & replace.
Hope this helps :)
Nov 21, 2009 | Lenovo 3000 G530 Notebook
I m buying 2nd hand lenovo 3000 g30 wanna know problems related to that series
We've used one here at the office for about a year. The keyboard messed up and kept typing "Q" so we replaced it. Other than that it's been pretty solid.
Nov 19, 2009 | Lenovo 3000 G530 Notebook
Lenovo G530-444635U laptop
For people having this same problem on Lenovo 3000 series laptops... Solution: On older ones you press Fn + F8.... for newers models you press the mouselock button that is located on the end of your multimedia buttons on the top corner of ur keyboard..
Aug 03, 2009 | Computers & Internet
Lenovo 3000 G530 Notebook Logo
118 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
