Question about Schumacher & Fast Charge Starter Charger
SE-4020 won't charge. Fan comes on but nothing else. Was using 40 amp charge and then went to boost. 40 amp showed it was charging by the gauge. Now nothing no sparks or anything. I don't see a fuse. Any ideas how to troubleshoot?
2 Suggested Answers
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
I have a 1994 f-150 pick up got a new battery & when i put the heat on it discharges & now truck won't.
You mean with the engine running? If the engine is running, the heater fan should be getting power from the alternator, not the battery. Does your battery light go off after engine is running? Or does the voltage gauge show normal charging when running?
If you can start the truck, have your charging system checked out. If it won't start now, have the battery charged up and try again. Then have the charging system checked. If it is good, your heater fan may have a short and drawing too much current, But a heater fan will run the battery down pretty quick, if the engine is not running.
Jan 06, 2013 | Cars & Trucks
Check Charging System/told not the alternator
Check your battery connections - where the cables connect to the battery posts AND where the cables connect to the starter/main power feed and where the ground cable connects to the engine and/or frame. A poor or corroded connection can cause intermittent problems and poor charging performance.
Mar 03, 2017 | 2003 Ford Expedition
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
94 softail custom won't start.
you probably smoked something boosting it with 200 amps. start looking for burnt wiring
Feb 03, 2018 | Motorcycles
My 96 Hyundai accent just died last night during a heavy rainfall. The lights wipers everything went and the car wouldn't start.I boosted it it started and lasted for another 10 or so minutes then died...
Yes that is part of it but not everything With the belt being loose the alernator cant not keep up with the supply and the demands that vehicle load has placed on the battery. Light wiper maybe the heater fan and probable radio. Now just dont tighten that belt when belt are loose it glazes and heats up rapidly now if you tighten the belt just inspect it if it is worn replace it like cracks or threads coming out if it look good go ahead tighten it it shouldnt squeel anyway. Now do you have a charging gauge use that as reference is it charging ?no gauge okay is battery light on? Run it for 5 minutes turn off for 5 minutes. Do you have to boost it to start? If you did the battery could of given all it is capable of giving may need to replace it, now how about the alternator hoping you have a battery gauge on the dash or voltmeter if you dont that okay tighten it for now any need to boost will be battey/alternator Hey do you want to check alternator with a screw driver and can you do it safely the vehicle has to be running get a real long a real longer screw driver but thin and it has to be able to stick when a magnet is placed on it , Here what you do as the vehicle is running the back of the alternator there is a bearing as it creates a charge a magnetic flux is developed this create a magnetic charge if you detect that magnet the alternator is charging. No magnet not charging. by the way if the alternator has a rear shield you cant do this test
Apr 23, 2011 | Hyundai Accent Cars & Trucks
Schumacher se 4020
I would check Mcmaster Carr online and search for part # 7178K14. This is a pair of 200 amp clamps for around $8.00. I use this business all the time. They ship really really fast. Good luck
Dec 13, 2009 | Schumacher & Fast Charge Starter Charger
Schumacher & Fast Charge Starter Charger  Logo
122 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Marvin
Marvin
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
