I have a Kyocera FS-2020 with a call service error F020
  • 43 Answers
SOURCE: kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Posted on Dec 16, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Posted on Feb 25, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
the menu does not open. What should I do?
Posted on Mar 25, 2011
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera FS-1016 Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Error message 20
F020 Main or expanded memory error
1. refix the main board and try.....
2. replace the expanded memory of the printer ........and try.......
3. replace the main board.........
Oct 21, 2009 | Kyocera FS-2000D Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
Paper fed through the Multi-purpose tray exits from the rear of the machine rather than from the top.
There will be a setting in the printer. Most people have it set to exit straight through as they run card stock from multipurpose tray. Should also be setting in print dialogue box
Apr 24, 2009 | Kyocera Mita FS-C5016N Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
1,065 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
