Question about Maytag MAH21PDD Commercial Front-Load Washer
Unbalance light is on my Maytag commercial washer and won't go off
2 Suggested Answers
  • 22 Answers
SOURCE: My maytag centennial commercial technology washer the sensing light keeps blinking and the lid want lock what do I do.
Wipe around the inner edges of top and ledge where door meets with machine to close. removing any particles of debris. then using a pipe cleaner carefully swipe out the opening where the locking unit is on door and machine latch. again ,removing debris
Posted on Jan 24, 2016
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Stops at 11 minutes left in cycle. will not spin or drain
Google ""Maytag Neptune load unbalance""
Read thru the post. I feel you have a Clutch malfunction even though you may not be see DC ot UC unbalance errors to the Console.
I'm seeing that around the 5 to 6 yr mark it's time for a Tub Seal replacement and possible Outer Tub and Spinner Support bearings should be replaced on the FAV6800A and FAV9800A machines. It's not too bad for most DIY owners.
Feb 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL FAV6800AW Washing Machine is receiving the dC error code on every load. It sits at 12 minutes remaining and attempts to spin several times before throwing the codes.
Hello zacas6,
dC/uC unbalance errors are caused almost all the time by a Clutch malfunction. Take a look this post and see if you want to DIY the repair. I will help you through the process.
I would also check the Tub Displacement Sensor. This a thru the lid check and you get a feel of how to enter Service Mode.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
I have some additional info if you decide to remove the Clutch in the machine if you are going to DIY.
Rich
Nov 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AW won't spin. COuld this be the
Hello leaweber,
Yes most times it is a Clutch malfunction . Is the machine failing with “dc” and or “UC” unbalance error codes in spin cycle? If you are you may have a Clutch malfunction or Tub Displacement Sensor failure more likely a Clutch issue.
You can do a quick TDS sensor check thru the lid just follow this from the Service Manual. If you machine will pass the TDS check the next step would be to remove the clutch from the machine and inspect as I describe in this post.
Tub Displacement Sensor check from the SM slightly modified;
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 for the details.
e. Press Hand Wash.
If you get these results your TDS sensor should be just fine. Time to look at a clutch repair/replacement. Let me know if you need help…. Rich aka dh1200s
Nov 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer becomes unbalances on heavy loads already replaced springs
I have same issue... My model i s FAV6800AWW. Failure Code is dC and uC for unbalance. I had replaced the clutch assembly 4 months ago (dyi) due to no spin.. it worked fine until now, where the unbalance issue is happening. For this issue, I have self tested the displacement sensor and it worked fine... I saw that on another forum that struts may have been issue.. so, I replaced the front struts. The back of the tub is hooked in by two suspension rods. The washer is leveled.. The tub spins/works when there is NO clothes in the tub... Only when I add any clothes, the tub starts to spin wildly until the displacement sensor kicks in and/or retrys or shuts things down... what's left to do??
Oct 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not happy with Maytag Neptune TL Washer
I assume you are taking dc/UC errors to the console. This is a classic problem with the FAV6800AW/FAV9800AW after the 3yr to 5 yr mark. I own the machine and decided to learn what was involved to repair the machine. Take a look at this post and see if will give you some insight to a DIY fix to resolve the unbalance errors. No fix for the tumbler action of twisting up the clothes. After a re-lube of the one-way roller clutch bearing I could wash a single pair of socks or over load the wash basket with bath towels and extra water in the tub with no unbalance errors (dc/UC).
Shout back if you have any questions.
Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube or replace if necessary. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Jun 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"Continous Unbalance"
we had the same problem. had a tech come out, he said it was the control board/motor. Never heard back from him with a quote to finish the repair (but he never billed me for the visit either, so hesitant to call him back!!), so used the 'diagnosis' and bought it on-line, $175. Husband installed, did NOT fix the problem. did more investigating on-line, decided to spend under $20 (eBay) on this: Maytag Washer Unbalance Switch #22003302 - cheaper than calling a repair person, so worth a try. Husband installed, FIXED!
Mar 15, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Maytag MAH21PDD Commercial Front-Load Washer Logo
207 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
