I have a Everstar model MPK-10CR looking for a service manual, P1 keeps coming up about drain
    Brigadier General:
  • 3,513 Answers
Hi
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely .However you do not need to have it plugged in for this method and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Just got one of these used, and also got the P1 error. Took the case off (which just involved a lot of Phillips head screwdriver turning), and found a sensor switch just to the left of the drain box inside the case. If I press on the sensor switch, the P1 error goes away, but then I get a blinking dot on the LCD display. Pressed the power button after that (while still holding the sensor switch) and it started working again. It looks like it was super-glued either originally or by a previous owner. Just needed to be re-positioned towards the top left corner where the drain pan sits. Just be careful when removing the case to not disconnect any of the wires going to the LCD display.
Sep 21, 2009 | Danby DPAC8020 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
