I have a Brother MFC-7420 that gets repeated paper jams. It will print the first page but then jams before the first is ejected. The first page is completed and there is a second page still blank inbetween the drum rear roller. If I remove both papers and it will again print the first page and jam the second. I have cleaned all of the pickup rollers and reseated the drum and toner cart repeatedly with no effect.
  • Gary Woodruff Aug 04, 2010
    Just would like a second opinion as this printer error started after transporting it to a new location. when I first tried to print it would not pick up a second page from the tray. If I removed and re-inserted the tray it would print one page and repeat the error. I removed the tray and toner etc. and cleaned the pickup rollers. I now get the paper jam as described in my first post. Thanks again, Gary
    Last "expert" sent me a link to brothers support pages. I have already tried all of the suggestions there. I am looking for help from a real expert not a link to support pages.
    Gary
  • 4,281 Answers
Turn off the printer.Pull toner cartridge from it then reconnect .Try with another cartridge then check. If still same issue then you need to do some servicing on fuser unit. For that open back cover of printer then you can find fuser unit open it from printer then open all parts of fuser unit like roller and other parts make sure roller is fine and there is not any small paper pieces.Clean sensor then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 04, 2010
    Do you have a procedure to remove the fuser? I cannot get it out of the rear of the printer to examine it.
    Thanks, Gary
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link….
http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/faq/faq_top.htm?reg=eu&c=eu_ot&lang=en&prod=mfc7420_all
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
    wtf - you send me a link to the mfg's website and you call that a solution? Please do not waste peoples time by simply providing a link to a support page for the hardware in question. do you have any real solutions or experience repairing printers?
  • 11,800 Answers
This happens because the second paper is loaded before the first one has finished printing. This is an error in the processor of the printer, the steps are no longer kept in check.
Sorry, there's nothing more that can be done to fix this printer, its processor is defective, time for a new one.
  • Azrael SRL Aug 04, 2010
    If it happened after a transport then maybe the fault is mechanical - maybe a gear slipped or is out of line, maybe a sensor is disconnected. You must dismantle it completely for a full inspection.
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420. New Brother Toner, New Drum, cleaned feed and separator rollers, changed paper, still jamming. Paper stuck around brown fuser roller. What can I do next?
Check whether the fuser rollers are free turning. If the paper is stopped at the ejection roller, the ejection roller needs to be replaced.
Dec 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 - paper jams in fuser unit -
Its probably the pickup roller and/or separator pads. Another possibility is a tear in the fuser heat cover. IF you can manually rotate the fuser(when its cool) you can see if the fuser roller has any problems. Last thing is make sure its looking at the right paper size. Maybe reset all software settings and start over? If its looking for one size and seeing another, it may cry jam.
Feb 02, 2018 | Brother Office Equipment & Supplies
Paper jams 1/2 way through drum/cartridge. Jams like an accordian, with 1/2 page printed. My printer is a Brother mfc 7420. About 2 years old.
Take the toner cartrige out, look around with a flashlight for a piece of paper or something that could jam the works. Check the movable tab that comes out of the front of the machine to hold paper up, maybe it has gotten crooked or something. Don't have anything in front of the machine to block the paper coming out. A can of compressed air can be used to blow the machine out.
Apr 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Paper keeps getting jammed at the back
What happened is that the fuser has quit working properly. You would need to have the fuser replaced.
Mar 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420 constant paper jam
need a little more info on this. does the paper look like it catches on something? is there any nicks or anything on the lead edge?
razors
Jan 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jamming
tell me where it jams so that i may help you! brother tec
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
61 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
