Question about Whirlpool Duet GHW9150P Front Load Washer
How do mi get rid of the rotten smell from my duete washer
  • 5,911 Answers
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Posted on Aug 03, 2010
How to get rid of rotten egg smell coming from washing machine
Check the drain where the wash machine is plumbed into it should have the blung to stop the smell comming out of the drain,also check the filter but it is very rare that the smell will come out of the washer it will be a drain issue that is backing up through the washer,if you havent got a u bend trap on the drain it will allow the drain gases to come back into the house.
hope that helps a little bit.
adrian
May 28, 2014 | Hotpoint Aquarius WD63 Front Load...
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jun 22, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I have the Duet, front loading washer and it now has a rotten egg smell every time you start it. Any suggestions on how to get rid of the smell?
This nasty smell is generally soap scum build-up. First thing i would do is to remove the bottom panel and clean the pump filter, (sometimes junk builds up there and stinks) if the inside of the pump is slimy, make sure your drain hose is not installed too deep, pull up the hose and see if it is wet and slimy at the end, if so, it is siphoning dirty water back into the machine after the cycle has ended. If that is the case, correct the drain hose so it is only 5-6" down the pipe, and then run a sanitary (hot) cycle, with nothing but a half gallon of bleach. Don't use that much bleach regularly though, as it can wear on hoses. After the machine is clean, make sure you leave the door open while not in use, use only HE (high efficiency) soap, and use a max of 3-4 Tablespoons. Also, to reduce odor, try sprinkling Oxi-clean powder in the door boot lining occasionally. Hope this helps..
Sep 17, 2008 | Whirlpool Washing Machines
We had a power failure whilst we were away for a week and all the contents of the freezer were rotten . the meat created a terrible smell which we cannot get rid of. how can we get rid of the smell because...
Too late, you'll have to get rid of it because the smell has been absorbed into the insulations....and when you bleackh the inside cabinet, the warm food will absorbe the smell again.
Sep 03, 2008 | Heating & Cooling
Damp smell
do a cycle and put a pack of unsweetened kool-aid lemonade flavor only in with it, this also works in diswashers...
Aug 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
166 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
