Question about Microsoft Xbox 360 Console
The power pack box to the system shows a red light...cant get the system turned on.
  • 767 Answers
Normaily when the power supply is pluged in it will be orange
and then turn red when the power button is pressed on the box.
If this is corect than the problem is with the console not the Power supply . 90% of the time it's two small transistor (F.E.T.s) part location UB51-2 are short . It's an easy fix if
your spare boards and a 50 watt soldering iron.
Posted on Aug 04, 2010
  • Microsoft Master
  • 441 Answers
If it's showing a red light, it may no longer be good. You can buy an XBOX 360 power supply & cord at the following website:
http://store.richspsxparts.com/ustexb360pos.html
Posted on Aug 03, 2010
I bought a Polaroid power pack, a pink one. I have tried to charge my cell phone Without success.
Red means it needs charging..... the light will turn green or go off when fully charged.
Aug 22, 2017 | Polaroid Cameras
When I turn the dsi on it shuts right off
Power shuts off during use
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged. Or the battery needs to be replaced if it does not hold a charge
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
Jun 01, 2011 | Dsi XL Pro Pack - Blue
No power getting to console power pack orange light i have tried unplug use different power cords talk microsoft no help
are you sure its not yellow try moveing wall sockets better yet hit the disk tray button if the brick cant supply enogh power it will then turn red or yellow if it stays orange it in stanby witch means it could be many problems if the system cant get enogh power to turn on it will show the 3 red rings but if the brick does change the brick is done
Dec 22, 2010 | Microsoft Xbox 360 Console
Timer worked for years. Just replaced lights. There were (8) but now there are (10). I didn't do the work and didn't know the wattage (and am not positive, but this looks like the unit). The lights work,...
Download manual for Malibu 200 Watt power pack
According to Malibu website information, your power pack is correct size if lights come on.
The way to figure is this
10 bulbs x 18 watts each = 180 Watts
so 200 watt power pack is good
Does the manual override work?
Rotate the on-off button counterclockwise
If override does not turn lights on-and-off, then timer has a short
Does the center dial turn when power is on?
If the dial is not turning, then power pack is kaput, or time of day is not set
Did you reset the time of day?
How to set time of day:
Put your trippers in place
Red = ON
Black = OFF
Plug in power pack
Rotate arrow (colored blue in diagram) as follows
Turn dial clockwise to present time of day (diagram shows 9 o'clock)
Turn dial one or more full revolutions, then return to present time of day
If center dial is still not rotating after setting time of day, it's time for new $50-80 power pack, unless you put a $15 timer on that plug. A cheap timer might work ... keep it going for couple more years.
Oct 08, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning...
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
May 25, 2010 | Intermatic Malibu 300W Power Pack...
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
3 red lights, but nothing turns on
sorry to say that is the Red ring of death your gonna have to send it to microsoft and they will repair it for free
Jun 14, 2009 | Microsoft Xbox 360 Console
Tiger Zoombox wont turn on
I solved my problem, after much digging, i found out that there is power at the lamp switch but no power at the the bulb. There is a yellow and orange pair from main switch to the board and a red and orange pair to the board. The red/orange pair connector, had orange side all black. could have been a lose connection but as soon as I shorted the connector on the board, it all came on as normal. YES I ALSO THOUGHT IT WAS THE BULB. I have had this system for 2 years and we use it atleast 4 hours a day. The old bulb still perfect.
Hope this helped.
Oct 27, 2008 | Televison & Video
GA-M57SLI-S4 wont power up !!! what to do !
Hi check the cables from the case to the mother board. They should be marked and the manual that came with the board ,this show you where to connect them on board The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] in most cases check to see if this is correctly connected
To test if there is no fault in the board or power pack. first visualy check the board to see if it shows a red led light when the power is turned on, if not the problem is in the power pack or the wall outlet.
second if the light is on, bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, check the processor and ram if not you have a faulty board.
Sep 17, 2008 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Red lights on my xbox360
The three red light problem can be solved by using what's called the X-Clamp Fix. The 3RL indicates a 'general hardware error'.
There are many websites that could help you with this, x-box scene in-particular has many tutorials. Or you can visit my own site..
http://modelshop.4t.com/
Click News and read through my 'pressure solution
Nov 20, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
231 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
