Color went crazy and it has almost double vision.
  • 121 Answers
Sounds like you need to replace your convergence ic's send me your make and model and I can post you a link where you can get your ic's plus free installation instructions plus free online tech support
Posted on Apr 25, 2008
Tmtmail.co.ukmy samsung projection tv has double vision and i dont know how to amend the lens can yu please help thank you
double vision in a rear projection tv has several reasons. one is convergence magnets are out of tune. u need to tune them which is back side of picture tubes. u please observe that which color is producing the double vision. the lens are firmly fixed & therefore need not to adjust. other option is to adjust the convergence of tv by going to service mode by remote.
Sep 13, 2011 | Samsung Televison & Video
VS 60703 has double vision in some spots and color off. Went to convergence to adjust and wavy green lines are on bottom and top of screen. Have never seen that before and cant adjust them out?
you might have leakage on the board from the tubes very common a few drops of fluid sometimes leak out of the tube just enough to cause crazy problems in set you need to check for this first unplug set and take the back off youll have to get a drop light or flash light so you can examine the module were the conversion ics are youll see a geen build up on module if you fluid leakage or you will actualy see on board it can be washed of very carefuly it will be the middle module as you face the tv from the back please make sure you have unit unpluged befor you look
May 19, 2010 | Mitsubishi VS-60703 60" Rear Projection...
Double vision with color distortion
how do i solve a double vision and color distortions
Oct 08, 2009 | Hitachi Televison & Video
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Double vision on color only
I like the Tech Most likely did a Color Configuration , Go into the Menu and Use the Arrow keys to scroll and look for " Color Calibration " run the test make sure you don't have " Bleeding" this is a term used by Color Tech's like myself to describe that Color are mixing together which is causing your current problem.
Do calibration First.
Mar 09, 2009 | HP Color LaserJet 2600n Printer
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Feb 12, 2009 | Canon imageRUNNER C3220 Color Copier
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
