Http://www.fixya.com/support/t690189-microtek_997m_monitor_doesnt_stay i have the same problem as this but don't know how to fix it
  • pmollica Aug 08, 2010
    I planned on fixing this myself, thats why i signed onto this site... can someone tell me how to fix this monitor?
    thankyou
  • 4,889 Answers
Your monitor's backlight inverter has failed, a common problem on LCDs. It is relatively easy to replace and should cost you around 30$ for the part. I can find it for you provided you can open the back cover and locate a small board that has connector to the power supply at a point marked "inv" or something like that. Get me the part number of the inverter and I will find it for you.
Posted on Aug 08, 2010
  • 4,472 Answers
You will need to find someone with soldering experience as it most likely needs some capacitors changed. Just contact any local tv repair or electronics repair shop and give them the information from that link and they should have no problem replacing it.
Thank you and good luck,
Lee
Posted on Aug 03, 2010
  • 3 more comments
  • Lee A.
    Lee A. Aug 09, 2010
    You replace the capacitors at the link that is on fixya that you already have. It is pretty self explanatory. If you don't have the soldering experience I would not recommend it. It is a fairly easy fix for someone with electronic expertise.
    Thank you,
    Lee
  • pmollica Aug 09, 2010
    No, I do not have soddering experience. I thought this would be something I could fix myself, apprarently not.
  • Lee A.
    Lee A. Aug 09, 2010
    Then I would not attempt it call around some electronics places and you should be able to have the repair made with the information you have for relatively cheap. Please take a moment to accept/rate my solution.
    Thanks again,
    Lee
    I appreciate your advise, but basically you are telling me that I can't fix it. I posted this so that I could save money by fixing it myself. Since I can't do that, the original advise from the original post I referenced was the best advise over all.
  • Lee A.
    Lee A. Aug 09, 2010
    Right that is all the information you need to make the repair if you have the ability to make it. being that you can't solder there is no further that you can go. Has nothing to do with the information I provided. I can tell you how to do it but if you can't do it then it is futile. If you open up the monitor and examine the capacitors you should find some bulged and those need to be replaced. I don't know what solution you were expecting but we can't fix it for you. I hope you will reconsider and rate my solution accordingly.
    Thanks,
    Lee
HI i have a acer X193HQ 18.5LCD MONITOR it fell off from my hands and now i am having two vertical lines one is ofblue color and another one with white colour. can you tell me how to fix it. I...
You may have damage the connection between the T-CON board and the LCD panel.
I would try reseating the ribbon cable between the T-CON board and the logic board, if that does not fix the problem, you will need new LCD panel.
See example here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Acer X193W LCD Monitor
When pluged in just the green light powers green then fades yellow but the sceen never lites
It is acting like it is not getting the video signal from the PC, unless there are problem inside the monitor, you should try it with another PC. All the cables are good?
Mar 13, 2011 | Microtek 211SD 21" LCD Monitor
The colors are off
Red, or green, blue cast? Check all the pins of the VGA cable first, and also try it with another PC to make sure it is not video card problem.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
Would like to know if a Microtek 815c lcd monitor has sound in it ?
You can easily tell by look at the on screen menu, and look for the Volume control buttons and a mini-stereo AUDIO line jack (Green color) in the back.
Oct 03, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
Screen keeps turning out
the problem is the power supply of your main board...you can replace the bulging/leak capacitors...to acces the power supply open the back cover of your tv..the power supply board is the pcboard which the mains supply is connected..you can also replace the whole power supply with a new one..resolder the board for its loose connections..
hope this helps good luck..
please rate my help...tnx for using fixya.
May 30, 2010 | Microtek 997M 19" Flat Panel LCD Monitor
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
Microtek monitor 997m
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Jul 01, 2009 | Computers & Internet
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but...
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Jan 04, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
