Question about Konica Minolta DiMAGE A1 Digital Camera
My Dimage A1 camera has been fuctioning perfectly. Recently, I changed from JPEG to RAW and took several images. I now am attempting to return to JPEG without success. I believe I am following instructions correctly on pages 80, 81, & 82 of the Instruction Manual, but I apparently am missing a step or two somewhere. When I click on "Image Size" and "Quality" in the Menu Section, either nothing happens or it pops back to the previous selection. When I right click on the Size and Quality, again, nothng happens. Suggestion?
  • Don trager Aug 03, 2010
    My comment is that the first answer is incredibly poor! I did not say I took many images in RAW. I only took 8! Secondly, what "memory" was refered to? This camera doesn't have an internal memory; it uses CompactFlash cards and the one in use has space left for 264 images in RAW! Is there someone available who is familiar with changing "Quality" settings in the Dimage A1?!!
    Lee the Deuce came up with the correct solution, that being re-setting the entire camera system. I've tried many other things in the last couple of days with no result at all.
    THANKS!!!!!!
  • 4,472 Answers
Have you tried the reset on the 1st menu page? Are you clicking the right button on the 4 way directional pad? use left and right to highlight and up and down to change. Hope this helps.
Thank you,
Lee
Posted on Aug 03, 2010
  • 2 more comments
    Lee:
    I'm confident I'm using the 4-way correctly.
    I've now re-set the camera, but with no result.
    Lee:
    I WAS WRONG!!!!!!!!!!!! The camera re-set now seems to have worked and I'm back to JPEG Fine.
    THANKS MUCH FOR YOUR HELP AND PATIENCE!!!!!!!
  • Lee A.
    Lee A. Aug 03, 2010
    You are very welcome. Please take a moment to accept/rate my solution accordingly.
    Thanks again,
    Lee
  • Don trager Aug 04, 2010
    Lee:
    Please let me know if my acceptance and rating didn't come through. Thanks again!
  • 3,230 Answers
Well it seems that problem is occur due to low camera memory, as you said in your question that you take many of the pictures in RAW file format, so first of all we suggest you to delete some of the pictures from memory and then try again.
If further you have the same problem then you may try to reset your camera to factory default settings (note. resetting the camera will delete all the settings and data from phone, so please make a backup first before resetting).
Good Luck!!
Thanks
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    Aug 10, 2010 | Nikon D40x Digital Camera
    Raw file quality not as good as jpeg
    RAW quality will always be at least as good as JPEG quality. The reason your JPEGs are coming out sharper is that the camera is actually doing post-processing on the RAW data, performing sharpening, white balance, contrast and brightness adjustment, etc., before saving the JPEG. The RAW data, as the name implies, is taken straight from the sensor, without the sharpening and other post-processing applied to it.
    May 04, 2008 | Konica Minolta DiMAGE A2 Digital Camera
    How many images can the DiMAGE A2 capture using a 256MB memory card ?
    In general, storage capacity depends on which image size and quality you have selected. For your information, here is the number of images recordable in a 256MB Compact Flash in the respective image size and quality. Since the image size may vary depending on scenes and subjects, these are approximate values only. Image size 3264x2448 / 3264x2176 / 2560x1920 / 2080x1560 /1600x1200 / 640x480 Std: 106 / 118 / 167 / 243 / 381 / 1043 FINE: 61 / 69 / 99 / 146 / 235 / 781 X.FIN: 31 / 35 / 50 / 75 / 124 / 594 TIFF: 10 / 11 / 17 / 25 / 43 / 245 RAW and JPEG: 15 / 16 / 17 / 18 / 19 / 20 RAW: 21 Movie : Image size 544x408 / 320x240 Movie(15fps) : 7 min. 9 sec / 13 min. 44 sec Movie(30fps) : 4 min. 15 sec / 7 min. 3 sec
    Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
    The extension of the recorded images become "*JPE"
    When the color profile is embedded in a JPEG image, the file extension becomes "*.JPE" (when setting at "Embedded Adobe RGB" with DiMAGE A1). Please check beforehand as the application software and printer which do not support JPE file cannot recognize JPE file.
    Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
    The recorded images by TIFF and RAW cannot be printed
    When printing the recorded images directly from the card slot of the printer, the printer which does not support TIFF and RAW cannot print those image files. Print the images with an application software which supports those file formats.
    The captured images cannot be played back.
    Check the following: 1. When there are several folders inside DCIM folder in the card, the images can be played back by the unit of folder. Select "View folder" from playback menu. 2. When the folder organization and the folder name are changed, the images may not be played back by the camera. Try it after returning to the initial set. 3. The image files edited or rotated on PC may not be played back. In this case it is impossible to play back the images by the camera.
    What size will the recorded image file be?
    In general, the file size of captured image depends on which image size and quality you have selected. Since the image size may vary depending on scenes and subjects, these are approximate values only. Image size 2560x1920 / 2080x1560 /1600x1200 / 640x480 Std: 1,491KB /1,025KB / 656KB / 240KB FINE: 2,520KB /1,704KB / 1,058KB / 320 KB X.FIN: 4,920KB / 3,289KB / 1,995KB / 420KB TIFF: 14,520KB / 9,506KB / 5,625KB / 900KB RAW: 7,373KB Movie: 522KB/s
    Is the DiMAGE A1 equipped with detail zoom function?
    Yes, the camera features x2 digital zoom. (Digital zoom does not work in RAW setting) When operate the digital zoom, the imaged size will be changed as follows: Setting image size 2560X1920,2080X1560 and 1600X1200: to 1280X960 Setting image size 640X480: No change
    In what file format does the DiMAGE 7i save the captured images?
    images are saved in the following format. Econ / Standard / Fine: JPEG (.jpg) Super Fine: TIFF (.tif) RAW: RAW (.mrw) Movie: Motion JPEG (.mov) Audio recording: WAVE (.wav) Symbols in brackets represent the file extension. Thumbnail data (.thm) is also saved for TIFF, Movie and RAW files.
    Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
    Konica Minolta DiMAGE A1 Digital Camera Logo
    Top Konica Minolta Cameras Experts
    Computer Links
    Steven Wander
    Steven Wander
    Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
