Question about Roper RAS8445KQ Top Load Washer
Washer wont drain - Roper RAS8445KQ Top Load Washer
  • 5,911 Answers
The most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for a replacement lid switch is 3949247. The lid strike (actuator) is 358684. The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. The lid strike is usually less than $5. Prices will vary between sites so shop and compare.
Another cause of a no drain issue can be a clogged drain pump or drain line. The following link explains how to access the drain pump and replace (if necessary):
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
These pumps are strictly mechanical (no electrical connections) and have one moving part - the impeller. You will need to remove the drain lines to inspect the pump interior as these pumps do not come apart. Check the drain lines and impeller area for any lodged items. If the pump is damaged and needs to be replaced, the part number is 3363394 and usually costs about $30.
CAUTION: You will need to drain the wash tub PRIOR to removing any of the drain lines. A quick and easy way is to use a wet/dry shop vac to remove the water. If you do not own a shop vac, simple gravity will work by placing the drain hose on the ground and allowing the water to run out. If this is not feasible because of the washer location, you will need to bail.
If you have questions, or need additional assistance, please post back and let me know. These are very simple repairs that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Aug 03, 2010
  • Jeff Rockwell
    Jeff Rockwell Aug 17, 2010
    @Robertk26,
    If the gearcase connection (as you call it) were defective, the washer would STILL drain. The drive motor is coupling directly to the drain pump and would still operate even if the motor coupling were broken. In addition, there is NO belt on this model washer. Roper is manufactured by Whirlpool. Whirlpool top loaders use a motor coupling in place of a drive belt. There is also NO fan on a washing machine. Last of all, the gearcase, if defective, usually averages about $150 to replace. Sears sometimes carries refurbished units for about $90. KNOW your appliances BEFORE posting solutions. This can be misleading to the consumer.
It may also be a bad connection in your gear box,you can check this by removing the transfer case at the bottom of most roper washers inspect the gears for damage if damaged replace the gear box usualy around $75.00 at Napa or Sears. If that is not it you may need to replace the belt which is located on the fan sometimes it gets to hot and breaks so it wont pump water if it has no belt a cheap fix around 15-20 dollars.Thanks
Posted on Aug 13, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Why wont my washer drain drain
Probably the pump is stopped up or gone bad . Replace
Nov 20, 2014 | Washing Machines
Kenmore elite he3t front loading washer wont drain
Here is one of the most common reasons a front load washer will not drain, you can try to fix this yourself following this guide:
Front Load Washer Wont Drain
Jan 10, 2014 | Washing Machines
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
My washer wont drain the water....It spins but wont drain
This must be a brand new Kenmore 20.6 cu. ft top freezer refrigerator. I have serviced over 10,000 refrigerators and freezers. Never once did i see one that had a washer, let alone one that spins but wont drain. Maybe you should try the washer forum.
Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
G.e. washer wont **** out rhe water
I did all the tips to check the pump. Took washer a part and no luck. I was ready to haul it to the dump. As a last resort I put drain cleaner (dollar tree brand) in the tub and ran the washer on hot. After the cycle I lowered the hose inot a bucket and turned the washer on Drain. I heard a pop and the pump was free. Works like a champ now.
Mar 13, 2010 | GE WBSR3140DW Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
363 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
