Question about Sony Playstation 3 (PS3) Console
Ps3 will not work with hdmi cable tried new cable still wont work but it will work on a other tv
  • 3 Answers
What tv you have? Maybe you must change some setings there.
Posted on Aug 03, 2010
HMDI 1 and 3 do not work (why) ?
Since you did not mention HDMI 2, I assume you have that connected to something else, and that is working properly. The following procedure is based on that assumption.
First, turn off everything connected to the set, and the TV itself. Disconnect the HDMI cable from whatever is going to HDMI 2 (leave the TV end alone for now) and connect it to the PS3. If the PS3 shows up on the TV, the problem is most likely a bad cable. To verify, turn off the PS3 and the TV, then move the known good HDMI cable to either HDMI 1 or 3. If the PS3 works on those also, the HDMI cable you had originally connected to the PS3 is defective. I know there are some bad ones out there; there is at least one lot with a right-angle connector on one end and a straight connector on the other that has a very high failure rate.
If the PS3 does not work with a known good cable to HDMI 2, then the PS3 has a problem. Try using a component (RGB) or composite (yellow end) connection to narrow down what the issue is.
If HDMI 1 and 3 do not work with a known good cable or any input source (DVR or cable box), then the HDMI switching circuit inside the TV is defective. Since the set is "new" that would be a warranty issue.
Jan 03, 2015 | Westinghouse 55" Class - LED - 1080p -...
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Used hdmi on another tv, wont work at home
what kind of cable, is it RCA plug that wont work.
if your TV support HDMI Cable since use the cable for your connection of your PS3 console to your TV at home...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont work with my lg lcd tv it is not the ps3 or the hdmi cable because it work on our othe tv which is a hitachi plasma tv.
when the ps3 turns on hold the on/off button untill you hear two beeps. this will make the ps3 look for the new cables and the tv
Oct 16, 2009 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Hdmi connection doesnt work on ps3
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
May 22, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
