Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
How to prime pump - Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 327 Answers
Well in the instruction booklet it tells you, if you don't have it then, look for a little bolt that unscrews, it may be a cap style can't miss it, unscrew and add water to top, only after all fittings are installed and tight, cause if there not, you will have to do this again, and depending on the tightness of you connections will determine if you can let the pump finish on its own, without priming again,, VERY IMPORTANT THAYT ITS AIRTIGHT, OR IT WILL JUST **** AIR.
Posted on Aug 11, 2010
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Isuzu kb 280 dt got a fuel starvation problem after it stands for a few days, when i pump the prime pump on top of fuel filter the problem is gon.
It could either be a fuel pipe between your prime pump and injector pump that sucks air so your diesel flows back into your fuel tank. Or you need to replace the prime pump.There is a rubber diaphragm in the prime pump that gets worn. Unfortunately need to buy a new prime pump. A simple sollution is to fit a non return valve to your fuel line. That need to be connected between the prime pump and fuel tank. Hope it helps. Blessings
Nov 09, 2012 | Isuzu Rodeo Sport Cars & Trucks
I prime the pump, and the sprinkler system does not hold pressure. I have also tried to prime the pump from the intake side. what happens there is that the pump actually begins to shoot water back out the...
You can't prime the pump with the same water source you are trying to build pressure in. Shut off all the water going to the house, use the neighbors hose or have several gallons (maybe 5) to prime the pump and continue priming pump until it starts to build head pressure then plug prime hole.
RJ
Jul 05, 2011 | Flotec Corrosion Resistant Shallow Well...
System error prime pump again. the pump does not
if the pump is not a self priming pump, it is possible that the windings may have burned out. use a hose to prime and then try in the Maint, position.
Oct 16, 2009 | RTO Safety Vacuum Release System - SR-500...
Pool pump won't prime. Impeller replaced, worked for a couple of days. I changed the filter now same as original problem won't prime. I thought perhaps it was clogged; however since it was running and...
sounds like a priming problem. look at the check valve in front of the pump in the suction line. sounds as if it is loosing its prime so you don't have enough water close enough to the pump to get it primed.
Feb 18, 2009 | Pentair 1.0 Hp Whisperflo Pump
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Priming problem
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Oct 21, 2007 | Starbucks Saeco Italia Digital Barista...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
193 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
