Question about Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site.
    Problem Solver:
  • 8 Answers
Www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Posted on Aug 05, 2010
  • Anonymous Aug 20, 2015
    which hyper link do i select from the list. there is about 15
My Kyocera KM-1635 will not allow me type anything after displaying call center C6050
Fusing related problem
: Abnormally low fuser unit thermistor temperature
Replace Fusing Thermistor
Check Thermal cutoff
Replace fuser
Nov 27, 2012 | Kyocera Copystar CS-5035 Copier
Download printer driver for cs 5035
go to www.copystar.co,
look under download, choose legacy black and white copiers MFP
the under the subcategory select print driver, choose the KX driver thats support your windows version, then run it and you good to go. let me know!
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 23, 2011 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
C-1120 on a CS 5035
The LCF lift 1 is not working
Jun 10, 2011 | Kyocera Copystar CS-5035 Copier
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Aug 06, 2010 | Kyocera Copystar CS-5035 Copier
Kyocera 6030
you type the ip address of the scanner and then through the web browser you then enter into the address book.General/contacts etc
cheers.
Sep 25, 2007 | Kyocera Copystar CS-5035 Copier
Kyocera Copystar CS-5035 Copier Logo
199 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
