Question about General Electric Microwave Oven
What does the F3 code mean? my microwave don't work any more.
  • 661 Answers
Posted on Aug 03, 2010
I have Amana microwave hdc182 displaying f3 code what dose this mean?
According to the tech info manual, when you get a code F3 you need to replace the HV/LV board. Here is a link to the manual for your reference.
Jul 02, 2015 | Amana Microwave Ovens
Have a GE Spacemaker (Model # JVM1650SH05). Microwave works for a few minutes then displays "F3" code. How can you tell if the Touchpad or Control Board is bad? When it is working for those few minutes,...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
Part number WB07X10959 this part can run over 100 bucks. If you shop around you could get a good price.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 28, 2013 | Microwave Ovens
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Hope this helps.
Feb 01, 2011 | General Electric PEB1590SMSS Stainless...
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
Microwave won't turn on code say's "F3"
The F3 error code for a GE microwave means the control is sensing a stuck or shorted key. Try pushing every button multiple times and do it firmly.
Hold a blowdryer in the corner of the keypad then slowly move it down as you peel it back (but not off). Take a sponge with the tiniest bit of dish soap and run it over both the sticky part (back of the circuits) and the place it is stuck to. Blowdry this til touchably dry and then reapply the kaypad face. Wait about 10 minutes until you plug in again for it to cool off.
If that doens't work, UNPLUG the unit and try to gain access to the electronic control board. If you can there may be a ribbon cable you can unplug from the board and try wiping the end of the cable hard between your thumb and index finger then wipe with a paper towel and reinsert the ribbon cable. May work but more than likely you will need to replace the touchpad.
Jun 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It has an f3 code on it what ledoes it mean
F3 means fault code number 3, I think this is Power Supply, or Magnetron.
Feb 09, 2010 | Samsung MW1030WA Microwave Oven
What does f3 mean in the window of a GE microwave
Code F3 is for 'shorted touch pad panel'.
However, this is not always the case.
Try the following;
Press (and hold) the Clear/Power button to reset the microwave and turned it off. Press it again to turn the microwave back on. set the clock. If the touch pach panel is okey, your microwave should work with no problem.
Oct 10, 2009 | GE Microwave Ovens
My ge microwave is showing a code of F3. model JES1034 what does this mean?
hello there
Tthe f3 code is referring to a faulty touch pad which may need to be replaced i would contact the manufacture of this microwave for a parts replacement
Jul 29, 2009 | GE Microwave Ovens
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
