Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 starts bleaking during the normal cycle - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
"F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir just needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
NOTE: "SUD" is a suds error detect that can commonly occur in conjunction with the "F02" error. This is a result of too much air being detected in the drainage system. In most cases, correcting the drainage problem will corect BOTH error codes.
Posted on Aug 03, 2010
Water is leaking out drain during cycling; cubes are thinner than normal. Does water valve need to be replaced or check rubber gasket?
Just above the pump there is a check valve that may be stuck open
during operation which will cause thin ice. Also make sure you have the o-ring on the bottom of the drain tube if it was removed during cleaning.
May 20, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Some water goes into the machine during the dry cycle. The factory tech told us this is normal???
dear its normal.... all the machine having 02 type of dry sis terms,,,your machine is condensation dry sisterm,,,,
Jan 30, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
I was washing towels on cotton (1) cold water , at the end of cycle during drying a F-02 keep flashing on the control panel. This is a new machine used about 3 months
Hello
F02 Is a suds error code or water is to soapy.You need to use the E A type soap.
Try running the machine on rinse and spin.And then go through a normal cycle with no soap.
Apr 04, 2011 | Ariston Technologies Washing Machines
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
Feb 10, 2011 | 2000 Toyota Camry Solara
My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Dishwasher gets stuck during cycle
have you ever cleaned the filter out in it? try unblocking the filter and it should drain freely and extinguish the error light
Sep 01, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
