Question about Lasko 2155a Window Mount Fan
I buy a lasco electric fan 3 to 4 mongths ago and then its stop working! can you tell what should i do! i think there something wrong with the small black things attach to the motor, if thats the problem, can you tell me where can i buy it!
  • 1,557 Answers
The small black thing is an in line relay. they dont burn out all that much the most common fault with fans is the coil some have thermal fuses that blow when they over heat but are very hard to find and repair unless you have done one before. considering how much the fan cost i think you would be beter of buying a new one than having it fixed
take care
Posted on Aug 03, 2010
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
How do I clean/take apart the Lasco tower fan, mine is working but extreamly dirty. Purchased 3 at WalMart and ; no paper work in boxes.
Easiest solution is going to be compressed air, not canned air for blowing out keyboards and computers, but compressed air from an air compressor. These fans are not designed to come apart for cleaning.. they're meant to be used a year, thrown away and you buy another one.
Mar 31, 2010 | Lasko 2530 Elite WindTower Fan
I get a warning message, "HIGH ENGINE TEMPERATURE-STOP ENGINE" from our 2002 S60 Volvo upon starting. The check engine light also comes on. The electric fan come on and runs for approx. 2-3 minutes....
Mine is doing the same thing. I have taken it to the shop and the mechanic can't find anything wrong with it. When he resets the diagnostic, the car runs fine for a few days then it happens again. I'm thinking it is something due to the cold temps here in NW Iowa. It is obviously not a cold weather car!
Feb 16, 2010 | 2002 Volvo S60
Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Dec 06, 2009 | Broan-NuTone N-668RP Combination Light Fan...
I have IBM 300pl. And it has strange fan problem.
A fan that no longer works will cause a heat problem. While it may not cause a complete failure, it can cause some strange things to start happening. Your best best is to shut the PC down and remove the cover. Restart the PC an determine which fan(s) has stopped working.
At this point, you can either 1) contact IBM for a replacement fan or 2) remove the fan yourself and google the name and model number of the fan to find a direct replacement and either order online or 3) visit a local PC repair shop to buy a replacement fan that matches the defective one.
Buying direct from IBM will probably cost the most, but will be the exact type needed for your PC. Buying locally will probably be cheaper and faster, but may not be an exact replacement unless it is the same model, etc.
When calling IBM you'll need the computer model, serial number and any other identifying numbers on it for them to help you out.
Sep 18, 2009 | IBM PC 300PL PC Desktop
Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Mar 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Hp Mecia Center m7060n fan failed, new fan not detected
the fan must be the correct fan
i guess you meant the CPU fan, ? desktops can have 2 or 3 fans.
the fan has 3 wires, in many cases, the 3rd wire is a RPM tachometer that if not correct the PC can not read RPM
if RPM reads 0 the PC will be very upset. and do that.
my guess you bought the wrong fan, and is super easy to do
giving the many fans
on some PCs the BIOS monitors the fan RPM and heat sink temperatures, or both, and tells yous fan bad for either failing
on my PC here, now, I can go in to bios and see both live sensors
RPM and Temperature. this allows for easier diagnosis
i dont think your PC has that page in BIOS to do monitors for trouble shooting, in fact mine has 3 fans all 3 are monitored, now.
high end PC .
this older desktop , only the m7200 pages are there. at hp.
so cant look at the fan nor BIOS.
i use a windows program that lets me watch the fan speeds
and all CPU and GPU core temperatures. (ask) its free.
the troubleshooting guide at HP stops short at this problem
says get it fixed. so you want to fix it your self sure.
so talk to one of the top, CPU/HEATSINK/FAN makers
and buy this from them.
if the fan spins fast and RPM is 0 wrong fant
if the fan spins fast and RPM is ok, then the BIOS dont like the CPU temperature... this has 3 causes.
fan dead. or slow. or wrong fan installed
heat sink fins packed in lint as all do ever year.
heat sink thermal bond compound failure, common.
Jul 18, 2017 | HP Media Center m7060n PC Desktop
Lasko 2155a Window Mount Fan Logo
210 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
