Question about Maytag Performa PAV2200
Washing machine blew the power breaker while washing and now will not start again
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
My washing machine has no power to it
Could have blown a circuit breaker in your electrical panel and if you have fuses could blow a fuse. You may have a short some place. Start with checking the cord and the plug its self. If you have a GFI receptacle you may have to reset that as well
Aug 30, 2016 | Washing Machines
I have been using my Bosch Xcel PBH 600 watt when suddenly it made a loud bang and stopped working.it also was smoking and blew the house mains switch...
If it blew the "house main" and the circuit breaker did not blow, it indicates the breaker for the unit and the associated circuit wiring has major problems and you need to get them checked asap by a licensed electrician. Don't use it again until the circuits are chceked.
Aug 20, 2014 | Washing Machines
Washer wont start back up after breaker blew
If it blew the breaker then something inside has shorted out. You should definitely not use it until a qualified engineer has opened it inspected and measured and determined the cause of the short.
Apr 04, 2014 | Maytag Neptune Washer
MODEL 45872 NO POWER IT BLEW THE BREAKER
Unplug your machine right away-you have a dead short it could be wiring that has rubbed through -check the wiring for any bare spots or rubbing on sharp edges,or its possible the motor is burned up-which means it takes alot of power to start it-more than you house hold wiring can come up with without blowing the breaker-hopefully just a wire though-cheers Denny
Oct 21, 2013 | Kenmore Washing Machines
Power went off in the house and the washer won't start up
It is likely that the circuit breaker or fuse which sends power from your electrical panel to your washer overloaded when the power came back on and either kicked if it is a circuit breaker or blew if it is a fuse.
Look in the circuit panel. If you have breakers look for one that is about half way off. Turn it on and all the way off and back on again to reset it. If you have fuses look for a blown fuse and replace it with the same amperage fuse as the one in there now. good luck and let me know as if this isnt the problem I have additional steps for you to take. I want to help you get your machine up and running so let me know.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
No power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Maytag Neptune Frontload Washer (MAH5500B)
you def have a direct short somewhere, try remiveg the 3 screwsfrom the top of hte console and tipping foward you ll see a cintrol boardand some wiring look for the "arcing" mark or wire off causing short.
Mar 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
