The VCR entrance cover on my Symphonic TR-WF13 TV/VCR combo is stuck in the open position and when I turn it on, it powers itself off after a few seconds
  • chuck163 Aug 03, 2010
    I tried inserting a tape by hand, but the TV still powers off.
    Thanks for your advice - I certainly want to avoid electrocution!
  • 4,889 Answers
Your problem can either be broken belt(that helps eject/load the tray or some kind of mechanical obstruction. Did you try pushing it in with your hand and see if it loads?
Posted on Aug 03, 2010
  • eagle338
    eagle338 Aug 03, 2010
    There is a mechanical obstruction inside the VCR and the self-check is failing. That is why the tv is powering off to prevent damaging the VCR. You will have to disassemble the tv and look for the onstruction and remove it provided you have prior experience in electronics. If not then it may not be a good idea to mess with it as the tv holds potentially lethal voltages that last for several days after its turned off and unplugged.
  • 4,472 Answers
Given the size and brand of this tv, your best option is to replace it. It isn't worth the time or money to look into getting it repaired. your only economically viable option is to replace it. If you need any help locating a replacement please let me know.
Thank you,
Lee
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
On a symphonic SC3819, can a stuck VCR tape be manually removed?
Yes, but for that you will gonna have to practically dismantle the tv to access the VHS mechanics and move them yourself  manually.
Jun 07, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic vhs tv turns off i hear the vcr after that it turns off
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Mar 16, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Power problem
Problem in tape transport mechanism, most likely...accordianman
Jul 31, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic WF-719 19 in. TV/VCR/DVD Combo turns on and automatically shuts off I cant get it to stay on
It is likely that your infrared LED, under the VCR mechanism, might be dirty or failing.
Mar 17, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
