Is a Canon Canoscan Lide 30 Scanner compatible with the 32-bit version of Windows 7 ? I have read somewhere that the Vista drivers can be used... is this correct?
  • 6,993 Answers
the answer is NO. Canon Canoscan Lide 30 Scanner is not compatible with Win 7 32-Bit.
Vista drivers can work, but might not function properly.
The Canon Canoscan Lide 30 Scanner is very much compatible with: Windows® 98/Me/2000/XP, Mac® OS 9.0 to 9.x, Mac OS X v10.1 or later**
Good luck.
Posted on Aug 03, 2010
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
Canolide20 doesnt install in windows 7
Your CanoScan LiDE is compatible with Windows 7 (32 Bit and 64 Bit) just make sure you install the correct driver for each system. If your system is a 32 Bit then you will need to download that driver and vice versa for the 64 Bit. See link below for drivers.
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_20#DriversAndSoftware
Nov 12, 2013 | Canon CanoScan LiDE 20 Scanner
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
There is no Windows 7 driver for my lide30 scanner.
Visit http://software.canon-europe.com/products/0000466.asp to download the Windows Vista drivers for the Canon CanoScan LiDE 30.You can try installing these using compatibility mode by right clicking on the downloaded files, and selecting 'troubleshoot compatibility' - select the option for 'worked in a previous version of windows' and then select vista
If this does not work, you should extract all of the downloaded files, press start, right click on 'my computer' select 'properties' and then click device manager. Right click on your unknown device and click 'update driver software' and then choose your extracted files to scan for the driver
Feb 25, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
My cannon canoscan lide 20 lide 30 driver,dose not install with windows 7
Do you have the 32-bit OS or the 64-bit OS? The Canon drivers will work in 32-bit Win7. However, Canon doesn't support these scanners in the 64-bit OS. The only way to make the scanner work in the 64-bit OS is to run either a dual boot system or a virtual computer with a supported OS. The Vista x64 bit driver doesn't work even if you use the compatibility mode.
If you have Win7 Ultimate, you can download Microsoft's Virtual PC and the XP mode for free. All other virtualization software options (Virtual PC, Parallels, VMWare) require a paid (licensed) version of the OS. Then install the scanner in the virtual computer and transfer files to external media to share it with the main computer. Dual boot systems have the same restriction of needing a valid OS.
I'm not aware of any Canon drivers for this scanner under UNIX.
I wish that I could be of more help.
Sep 02, 2010 | Computers & Internet
Driver for canoscan lide 35 for windows 7, 64 bits
this is the support site ...and the driver I found there is for windows 7 but on 32..Cause they do not have one for 64 bits OS yu should download and try the Vista one on 64 ..cause the compatibility is usually high and it s worth give it a try ..If not the only way you will be able to use is if you reinstall the windows & on 32..You will not feel much difference but the driver's compatibilities will be easier to match
May 31, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Is canonscan LiDE20/30 compatible with wndows 7
Here is the link for downloading the drivers for canoscan lide 20 for windows 7 (compatible with XP, Vista e.t.c).
Canoscan lide 30 does not support windows 7, here are the drivers for Vista.
Thanks and regards
Stelios
Feb 25, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
I have canoscanlide 30 i canot install the toolbox to my pc windown vista whay can i do
two possibilities...
1. the toolbox software may need to be installed as administrator and in compatibility mode
2. it may not be installable if your pc is a 64 bit pc and your toolbox software is 32 bit... this is a common issue...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Compatibility question
You need to download the Windows Vista driver from the Canon website. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
