Question about E-Machines eMachines Desktop PC
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not remove it. It has just been popping up automatically.
    Guru:
  • 1,082 Answers
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Posted on Aug 03, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
Screen is mainly blank except for one faint line. Have put new batts in and checked for any dampness on inside, every thing looks good. Still nothing on screen.
It is possible that the screen contrast is too light.
To adjust the screen contrast follow the procedure:
  1. Press [2nd] key and release it.
  2. Press and Hold the UpArrow key to darken or DownArrow to lighten. Keep pressing until contrast is adequate.
Jan 03, 2010 | Texas Instruments TI-83 Plus Calculator
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
There is no feasible way to fix this. The problem is a short in the circuitry of your flat screen. If the monitor is off warranty, it's cheaper to replace the monitor than to have it repaired.
Jun 02, 2009 | Dell Dimension 2400 PC Desktop
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Projection defect
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
May 21, 2008 | Panasonic PT-52LCX65 44" HDTV
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
250 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
