Canon mx 700, tells me paper selected from front tray is wrong size. It doesent have any paper in the front tray! Whats wrong with this worthless printer
    Genius:
  • 1,478 Answers
This is a problem that is not common on this kind of device, it will require a diagnose, if you need more information on this, drop your comment for me to follow up.
Take care.
Posted on Aug 04, 2010
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
SHARP AR5320. HOW TO REMOVE SEIZED PAPER.
Follow these steps to change a tray's paper size setting.
1) Hold down the [PAPER SIZE ENTER] key for more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
2) If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
3) Use the [ORIGINAL SIZE ENTER] key to select the paper size.
The indicator of the selected paper size lights up.
4) Squeeze the lock lever of the front guide and slide the front guide to
match the width of the paper, and move the left guide to the
appropriate slot as marked on the tray.
5) Press the [START] key and then the [PAPER SIZE ENTER] key.
Jan 29, 2011 | Sharp Office Equipment & Supplies
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Oct 10, 2009 | Office Equipment & Supplies
Sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Jun 19, 2009 | Sharp MX-2700N Color Copier
FRONT PAPER FEED
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Feb 05, 2009 | Canon PIXMA MX850 Multifunction Printer
Will not print
go to this page: "http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651#SupportDetailAct"
seems to be related to paper jams or wrong size of paper being placed in the front tray. if loading odd (e.g.: credit card sized), paper sizes, they need to be loaded into the rear tray.
good luck!
Jan 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
"Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Dec 03, 2008 | Sharp MX-2300N Color Copier
Red light comes on above paper tray selection
whats the make and model. if you have paper in tray maybe the fax doesn't see it due to wrong paper size detected or broken flag sensor or faulty sensor.
Jun 14, 2008 | Sharp Office Equipment & Supplies
16 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
