Question about Minolta EP1030/1030F CS/PRO Copier
Minolta EP 1030 Problem: dark vertical line ca 1 cm wide on the copy. How to clean this old copymachine? Yours harald@mercato.no
  • Minolta Master
  • 1,297 Answers
Remove the image unit,remove the charge corone block and clean.It is dirty.
Posted on Aug 09, 2010
What is Error Code E1 on a Minolta EP-2010
Sir/Mam,
Your ATDC sensor located in the developing unit or main board is bad. Have you recently had the developer replaced in the machine and did the person doing that use a vacuum cleaner to clean out the old developer if so then the static electricity form the vacuum cleaned destroyed the sensor. NEVER USE A VACUUM Cleaner to remove developer in the developer unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 21, 2014 | Minolta Office Equipment & Supplies
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
My minolta ep 1030 is printing copies with a line down the page
Check the hot roller for a scratched surface. Otherwise you may have a bad photoconductor.
Jan 07, 2011 | Minolta EP1030/1030F CS/PRO Copier
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
204 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
