Question about Chef's Choice 677 Cordless Electric Kettle
My kettle is turned on and the switch lights up but it does not heat up.
  • 1,557 Answers
In this case i would say the element has burned out they are not a servicable unit and would be cheaper to replace than fix
best of luck.
Posted on Aug 03, 2010
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Jul 20, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Feb 18, 2012 | Chef's Choice 677 Cordless Electric Kettle
When the kettle is switched on, the light comes on...
sounds like the element has died. If it's still under warranty, take it back. If it's not under warranty, contact an electrician or appliance repair person. Unless it's an expensive kettle though, it's probably not worthwhile fixing, as elements can sometimes be as expensive as a new kettle
May 20, 2010 | Kitchen Appliances - Others
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
Apr 07, 2008 | Kitchen Appliances - Others
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Chef's Choice 677 Cordless Electric Kettle Logo
452 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Rommel Balcita
Tom Chichester
AJMAL KHAN
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
