Question about Aiwa HV-MX1 VHS VCR
I turn it on and in one second it shot itself off without even put cassette
Vcr gx1100 aiwa da se pomeri kanal na av
Posted on Aug 03, 2010
I have a Advent 8315 the turns itself off when unplugged even when its fully charged
Try removing your battery, wait 30 seconds and plug it back in and see if it powers up. If not, take your battery out, put it in the freezer overnight, take it out and let it sit in room temperature for 12 hours and then put it back in ....DO NOT put it in right out of the freezer and into the laptop ...let it warm up .... after 12 hours, try it and see if it shows 0% and charging ...if it still shows 100% charged, your battery is shot. Let me know how it goes
Mar 16, 2014 | Advent Computers & Internet
The tape pops back out
The loading mechanism has to seat the cassette in the play position. In this case the mechanism is unable to do this. If you cannot get any cassette to load, the vcr may be shot. It probably could be repaired but you would have to consider cost
Jan 06, 2013 | Magnavox ZV450MW8 DVD Recorder VCR
Motherboard goes for 3 seconds then shots itself
hi i like to help. first off, put back the old processor and reset the motherboard. you''ll find the jumper caps near the battery or you can read the label on the board something like jbat1. put the jumper cap on pins 2 and 3. wait 10 secs to reset the board then put it back to pins 1 and 2. The board should work now. to upgrade your processor i think you have to upgrade the bios first. download it from the manufacturers website. after bios update, replace the procesoor and it should work again.
Apr 17, 2012 | MSI K7T Pro2-A MS6330 (K7TTURBO-R)...
I have a TDK HD-01 head demagnetizer for cassette decks, but I have lost the instructions. Could you help?
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
Jan 07, 2011 | Audio Players & Recorders
I have a canon MV 830.Please could you tell me when i put the cassette into the camcorder it keeps beeping then asks me to eject the cassette. Is this expensive to fix?
My MV830 would load without a cassette; but freeze, beep 3 times and eject if a cassette was inserted. I read the following thread with a great deal of scepticism and concern that I would damage my MV830 camcorder even more; but what did I have to lose? I loaded the compartment without a cassette, hit it firmly 3 times on the tape loading side and the issue was gone. It now works perfectly! Technology is fantastic...
http://www.fixya.com/support/t238707-will_not_load_tape
Dec 06, 2010 | Canon MV830 Mini DV Digital Camcorder
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
CD keeps ejecting without playing.
try reformatting the cd or try a cleaning cd, the more you pay the better the cleaning cd
Nov 06, 2009 | Pioneer FH-P4400 CD / Cassette Player
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Cassette stuck in VCR
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
Oct 28, 2006 | GPX TVR950 VCR
Aiwa HV-MX1 VHS VCR Logo
162 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
