Question about KitchenAid Pro Line Coffeemaker Coffee Maker
Too much water going into filter making coffee very wet
    Top Expert:
  • KitchenAid Master
  • 77,544 Answers
Making coffee very wet? sorry have no idea what u mean by this statement, please clarify this statement, coffee is a liquid composed of water.
Posted on Aug 03, 2010
I have a Keurig b145 given to me I purchased some new kcups They taste funny. I am wondering if there a filter that needs changing or what in the b145? It has not prompted me to descale it.
try using only distilled water, tap water has minerals in it and can cause buildup and harbor bacteria YUMMY
give it a good cleaning first.
I'm not a big coffee drinker but when (don't try this as all other coffee will taste like GAK )
I make it, I use a french press and Fiji water and 100 Hawaiian Coffee Kauai Coffee Company Buy Coffee Online
Brew Perfect French Press Coffee with this Recipe Crema co
How To Make French Press Coffee
Jay the pool pump motor repair guy longwood Florida 32750
Nov 21, 2017 | Keurig Coffee Makers & Espresso Machines
When I use the filter after a previous cup and it is still wet the coffee comes out very watery and undrinkable. When the filter is dry in the morning the coffee is perfect.
I'd suggest you try tamping with a bit more pressure, watery coffee is typically the result of water getting "around" the ground coffee as opposed to getting forced through it.
Feb 16, 2014 | Breville Die Cast 800ESXL Espresso Machine
We recently obtained a used B70 coffee pot from my mother-in-law. There is a charcoal filter, but I am not sure where to put it. It is in some kind of holder that has 1 through 12 on it. Do I just drop...
Keurig has the manuals for their coffee makers here: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The B70 is their Platinum Brewing system. The direct link to the manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx .
You need to put the filter into the reservoir at an angle (caddy-corner to the reservoir). According to user comments, it works best going from the front left corner and back to the right. Others find they need to wet the filter for 30 minutes and then squeeze out some of the excess water to loosen the filter. This site has comments on using the filter with the Keurig brewers: http://www.keurig.com/accessories/water-filter-starter-kit .
I hope this helps.
Jul 19, 2011 | Keurig B70 Coffee Maker
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    I need a replacement filter for my kenmore coffee maker item#69768
    If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
    http://www.sears.com/shc/s/p_10153_12605_00869768000P
    Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
    Water not filtering quick enough, basket overflows
    Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
    Apr 28, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
    I have water in the discard container and wet grounds. They used to be dry brickets.
    Hi
    There are a couple of things that make wet grounds. One is a very coarse coffee. It should be like granulated sugar.
    The second is your thumb screw is stripped, and needs to be replaced. Thumb screw holds the filter screen in in the brew head.
    Dec 04, 2009 | Saeco Magic De Luxe Espresso Machine
    Water is not filtering through grounds
    The grind on the coffee is too fine, try making it a little coarser.
    Jul 12, 2009 | Coffee Makers & Espresso Machines
    Saeco Vienna: water does not go through to the main unit
    on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
    May 20, 2008 | Saeco Caffe Charisma Espresso Machine
    Hamilton Beach 40616 Perculator
    Try to replace the delivery (ascending) pipe in the middle.
    Hope this can help you
    Mar 24, 2008 | Hamilton Beach 40616 Coffee Maker
    KitchenAid Pro Line Coffeemaker Coffee Maker Logo
    12 people viewed this question
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
