Question about Refrigerators
Refrig does not get col or work but the freezer works
    Genius:
  • 1,073 Answers
Is the fan running in the freezer if not go there first
Posted on Apr 25, 2008
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Frig not getting cold enough
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 08, 2010 | Amana ABB1927DE Bottom Freezer...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side refrig. - Freezer not working but refrig. is
could be many thing , low on freeon also defrost problum , open panel of your freezer side and check coil behind it
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
