I have an Epson TX100 and accidentally dropped a tiny piece of plastic inside the space for inserting paper. I was managed to dismantle the printer by screwing all the nails and take out the plastic piece. However, I could not switch on my printer after that though I made sure that all the plugs are connected. I suspect that while dismantling the printer, I might have caused some damage. As such it cannot be turned on.
    President:
  • 2,571 Answers
All you can do is strip it down again and check all the cables.
Posted on Aug 03, 2010
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Feb 08, 2014 | Epson TX100 Series
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
There's a general problem to my Epson TX100. the two orange light is blinking. What should I do? Do I have to reset my printer? What software should I use?
You have to reset your printer. Go to this link to download the program.
http://www.ngedownload.com/epson-tx100-resetter-wast-ink-pad-full.htm
NOTE: you have to replace the waste ink pad inside your printer to prevent flooding of waste ink.
Jan 19, 2010 | Epson Stylus NX400 InkJet Printer
There is a tiny piece of paper stuck inside that we can see but can't manage to get out. How do we take the printer apart to get the paper out without damaging the printer?
Instead of taking it apart,try to get a stiff piece of paper or a thin cardboard to force into the paper path to push the stuck paper out.
Oct 09, 2009 | HP PhotoSmart 7960 InkJet Printer
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Inserting A4 paper
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Apr 12, 2007 | Epson Stylus Photo 830 InkJet Printer
35 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
