Question about Garden
I have a Gilson 8HP snowblower. What should the gap be (in mm) on a Briggs and Stratton 8 HP Model no 190402 Type 0992-02
  • John Courtney
    John Courtney Feb 14, 2014
    Magnito Gap is the thickness of 2 piecse of paper, works well, spark plug gap is 0.030, the points gap is 0.020
  • John Courtney
    I own the same Gilson machine, good unit, Magnito air Gap between the magnito and the flywheel is the thickness of 2 pieces of paper 0.080 to 0.012 paper works well, turn the magnetic side of the flywheel toward the maginto when making the air gap adjustment, spark plug gap is 0.030, the points gap is 0.020
  • 708 Answers
SOURCE: 10 HP Briggs and Stratton Throttle assembly
www.briggsandstratton.com/maint_repair/manual_and_more/
Then print in model no etc. You should get owners manual as well as parts list.
Posted on May 05, 2009
  • 376 Answers
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Posted on Jun 12, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
SOURCE: need point gap setting for 8 hp Briggs and
need coil gap setting for 2-8 hp briggs stratton
Posted on Dec 02, 2009
seanpwright
  • 2030 Answers
SOURCE: Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Feb 05, 2010
Briggs and stratton 8hp wont run without choke
Have you cleaned fuel line and tank to make sure no restrictions to carburetor?
Aug 26, 2012 | Briggs & Stratton Ignition Kit 2-8 HP...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
What is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
8hp briggs and stratton in a go cart. is feeling very underpowered compared to what i remember. hasnt done much for last 8 years. done basics but no better? any ideas
Make sure the governor baffle is working freely. and the carb has no crud in it. Chk out this site:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Aug 04, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Drive belt and a manual for 8 hp tomahawk chipper shredder
did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
Jun 08, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
