Question about Cameras
I have a Canon Power Shot SD790Is DIGITAL ELPH and the camera keeps saying card error, card locked. I am aware there is a switch on the side of the card, and it is currently unlocked. When I turn the camera on however, it still says there is an error and that it is locked! Please help! Thanks.
  • 6,831 Answers
Hello
Ok, here is something you can try:
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Posted on Aug 03, 2010
The canon says "memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 12, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
WHAT IS THE BIGGEST SIZE CARD AND WHAT TYPE FOR THE canon powershot SD630 ELPH?
The biggest size SD card compatible with Canon Power Shot SD630 is 1 GB. Visit canon showroom to buy SD card.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera says memory card error, card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 22, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
SD630 camera states error memory card? New Card 2GB SD Card. Then it states card locked removed card and still says card locked. Will not let me go into format on tools. please answer.Do I need to just...
On the side of the SD card there is a little switch for locking the memory card to prevent erasure or writing. Make sure it is not locked. After that try a smaller size card. After that junk it.
Nov 18, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Card locked problem
If you've already tried the slide switch, see this link for additional things that you can try.
Aug 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
LCD shows MEMORY LOCKED even thought card is NOT LOCKED!
Go thru all the pages on the camera setup in the camera. You may find a memory lock conrol. That is there to keep you from accidently erasing photos.
May 03, 2009 | Canon Cameras
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
