Machine does not start when a program is selected
  • 6 more comments
  • patejaya Sep 05, 2008
    how do you un lock or re set the control panel or do think it the membrane led touch panel??
  • Anonymous Sep 22, 2008
    will not start after door is closed
  • Anonymous Feb 01, 2009
    how do i use it
  • DKAMYSZ Feb 14, 2009
    CONTROL LOCKED LIGHT ON MACHINE WILL NOT START
  • Anonymous Mar 15, 2009
    how do i unlock the control panel
  • glendamom May 07, 2009
    how do you unlock the control panel on the maytag neptune:
  • Anonymous May 09, 2009
    my machine will not start either!
  • Anonymous May 13, 2009
    control panel locked,red light on, can not use washer at all!!! please help
    Genius:
  • 1,073 Answers
Have you got the control panel locked out,
Posted on Apr 25, 2008
  • judy wright Nov 07, 2011
    i have a hoover 550 did a cycle of washing the door wouldnt open waited ages still wouldnt open . had to force it open now it wont work please help me
Control panel locked and machine will not start OR unlock---it's stuck!
Posted on Apr 13, 2009
Hoe to delete programmes?
If you are on a Windows machine you would go to Start, Control Panel and Programs and select Uninstall a program than select the program you want to uninstall.
Aug 18, 2014 | Computers & Internet
Dishwasher
It could be you opened the door before it had fully completed a program, and then turned it off. My Hotpoint machine has to be reset in these circumstances otherwise the next time it is turned on, it appears to let you select a different program but when you close the door resumes the program it was running when it was interrupted.
You don't say which model you have, so I cant give you a definitive answer, but you could try the following sequence which works on my Hotpoint:
1. Open door and switch machine on.2. Press and hold down the P button for several seconds until it gives a series of beeps (mine = 3 beeps).3. Release P button.4. Select the program you want in the usual way using the P button.5. Close door, and the machine should then run the selected program.
Hope this helps.
Sep 18, 2012 | Hotpoint Dishwashers
Hi there, I have a Euromaid WM5 and suspect it was overloaded as it stopped near the end of the cycle. We turned it off at the power as it wouldn't reset and couldn't get clothes out. It has been off...
I think, that if you want to cancel the program, you have to select correct program on selector knob. When turning the knob observe the display. When correct program is selected, it will show spin speed and temperature.
I have also managed to reset the machine by entering service mode. Turn it off, select Cotton program. While keeping Start/Cancel button pressed, turn it on. It showed E 05, then whole display started blinking. Using the same button it started spinning. After turning it off and on again, the machine was reseted.
Feb 21, 2011 | Washing Machines
I havea mx310 but have lost the manual - how do i set up to scan photos?
You can download your manual from this site:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Solution: Setting scan methods for the button (Windows) - MX310
Scanning using the Operation Panel
You can scan documents using the operation panel.
Important
bullet.gifDo not disconnect or connect the USB cable while the machine is in use.
bullet.gifIn Windows XP, the program selection dialog box may open when you press the Color Start or Black Start button on the machine for the first time. In that case, select MP Navigator EX, then select Always use this program for this action and click 'OK'. From the next time, MP Navigator EX will start automatically regardless of the selected scan mode.
arrow.gifSelecting a Response to Commands from the Operation Panel
1. Place the document face-down on the platen.
2. Press the Scan button on the machine.
The machine enters Scan Mode.
3. Press the Color Start or Black Start button on the machine.
MP Navigator EX starts on the connected computer. Scan documents on the platen or ADF (Auto Document Feeder) using MP Navigator EX.
Trust this is helpful.
Dec 14, 2010 | Canon PIXMA MX310 All-In-One Printer
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
I need to send a mass fax once a week
you need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
function-7-2-start [this is where you program your numbers]
function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Washing machine problem
Possible sticking door lock or a faulty PCB located in the back of machine, however watch the red light and count the flash pulses, if there is a compnent fault the self diagnostics should emit a fault code, the light will pulse and then pause, you need to count the pulses between the gaps.
Jan 04, 2008 | Washing Machines
Washing Machines Logo
905 people viewed this question
Top Washing Machines Experts
