Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
Not audio from de front , went i plug audifon fron the fron theres no audio
  • 2,427 Answers
That's cause the front audio connectors are not connected.. To do this open up the tower.. Now locate the wires from the front connector.. Its labled j audio.. Now on the main board there is a jack for it,, some pins labled audio as well if its not labled then look for the pins in the same fashion of the jack.. If u see some plastic jumpers bridiging 2 pins remove it.. Plug in your front audio connector.. That's it your done..
Posted on Aug 03, 2010
Testimonial: "thank you so much , do you have any picture?"
Firing order diagram for 1989 chevrolet p 20
It's a V8? 1-8-4-3-6-5-7-2 for a Chevrolet.
Starting from de front cilinder, right bank, N?1, from fron to rear, 1,2,3,4.
Left bank from front to rear; 5, 6, 7, 8.
Distribuitor rotates clockwise.
Jan 02, 2013 | Cars & Trucks
I have the Dell 5650 Computer Speakers..I had to reolad the audio driver.. now, the two fron speakers and the center speaker under the monitor work, but the two rear speakers are not producing sound..I...
If you are using Sound Blaster, go into "All Programs" and open the "Creative File" and then the "Audio Console", left click the "CMSS 3D" tab, under the "CMSS Modes" click on the selection box and select "CMSS". They should start working at once.
Sep 04, 2010 | Dell 5650 Computer Speakers
My sony str de 835 display went out. sometimes
Most likly bad solder connections on the display board. Look for solder rings on the LCD. You must remove the front panel to gain access.
Mar 22, 2010 | Audio Players & Recorders
Before i used to play games on my ps3 with de normal cable and everything went fine but recently i started using the hdmi cable but it doesnot display de menu and it directly plays the game and when i got...
when you turn on the ps3 from the back and then you hit the power button in the front hold that front power button until it beeps at you and then it will work
Sep 22, 2009 | Video Game Consoles & Games
Audi a4 front de-mister problem
ONE OF THE HEATER DISTRIBUTION FLAP MOTORS DEFECTIVE. UNSCREW GLOVEBOX AND YOU WILL SEE THE MOTORS.TEST WITH THE BLOWERS ON ,TRY EACH VENT TO FIND FAULTY MOTOR...
Nov 28, 2008 | 2005 Audi A4
Where to hookup front panel (PIII-3754LMR - )
Hello!
In this image USB connectors for a fron pannel header are marked as Q and R, and the audio connector for a fron pannel is marked U
Hope this helps!
Sep 30, 2008 | Computers & Internet
Rainbow colors after a lightning storm
you need to borrow or rent from a repair shop a degaussing coil. Its a big coil of wire that plugs in and has a switch on it. How you use it? With the coil plugged in,but not switched on ,hold the coil in front center , about two inches fron the picture tube. Now switch on the coil and slowly rotate the coil in a circle all the way around the picture tube and at the same time pulling slowy away fron the front of the picture tube. Keep doing the circular motion till you reach about three feet from the front of the tube, turn the coil sideways fron the tube and quickly shut off the coil. This is done with the tv set on. The set should look clear now ,with no color blotches on the corners or the rest of the picture. If it dosent then the pictre tube is bad. If it does look good, shut off the tv set for a hour or so , turn back on the tv set, Is the colors back on the screen. Yes , then ther thermistor or degaussing circuit needs to be serviced, and this is something you will need to call in a tech to service for you cause theres extremly high voltage inside these sets and not for a handi-person to tinker with. But if its good then your all set. Good Luck
Jun 14, 2006 | Samsung TXN2771HF 27" TV
HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
