Question about ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor
A cada 5 segundos aparece a mensagem MEMORY RECALL OK? Mesmo se eo pressiono a tecla 1 ou 2! não desaparece! Me ajudem Please!
2 Suggested Answers
  • 79 Answers
SOURCE: Memory Recall OK
it may be due to stuck setting button on lcd monitor or due to faulty circuit ... try to see if buttons are stuck ..nudge them a little to see if that makes a difference otherwise call the company technician.
Posted on Aug 08, 2009
Como se reativa a fn?
Dear Ary,
I'll first answer in English and then in Portuguese..
The 'Fn' key is not reactivated. As a matter of fact, it 'activates' the special functions marked in the same color or with the same pattern as is shown in the 'Fn' key. Pressing and holding the 'Fn' key while you press any of the function keys will enable the function marked on those keys (increase or decrease brightness, increase or decrease sound, open the DVD player, lock/unlock the laptop, start the browser, etc).
In the case your problem is that the 'Fn' key is not performing the actions described, along the other function keys, maybe it could be caused by a defective contact matrix under that key. In this case, you will have to take your laptop to an authorized service repair shop and have its keyboard repaired or replaced.
Hope it helps!
Agora em Portugues:
A tecla 'Fn' nao e reativada. Na verdade, ela 'ativa' as funcoes especiais das teclas de funcoes (marcadas de F1 ate F12 no topo do teclado) que estao na mesma cor ou com o mesmo padrao da tecla 'Fn'. Pressionando e mantendo pressionada a tecla 'Fn' enquanto voce pressiona qualquer uma daquelas teclas permitira executar a funcao marcada nas mesmas (aumentar ou diminuir o brilho da tela, aumentar ou diminuir o som, abrir o browser, bloquear ou desbloquear o laptop, etc).
Se o problema que voce menciona e o da tecla nao cumprir com essa funcao de ativar a funcao das demais, pode ser que a matriz de contatos do teclado esteja gasta - ai sera necessario levar o laptop a uma assistencia tecnica para reparar ou trocar o teclado.
Espero ter ajudado!
Miguel L. Martins
(P.S.: nao uso os caracteres acentuados porque o sistema da Fixya nao permite caracteres Unicode, somente caracteres em ingles).
Nov 05, 2013 | Acer Aspire One PC Notebook
PRINTER ERRO TEMPERAT FUSORA
Olá Primeiro:
1. Troque seu no-break, estabilizador ou transformador por um com capacidade maior que 1000Watts.
2. Ligue a impressora e agurarde apresentar a mensagem ERROR PRINTER TEMPERAT FUSORA
3. Pressione Seta pra Baixo.
4. Apeter: *
5. Aperte: #
6. Presisione: OK
7. Substituir 0 pelo 1
8. Pressione o Botao Vermelho.
9. Depois: Seta pra Baixo.
10.# (entra no modo apagmento)
11. Apertar letra T
12. Desligar impressora por 5 segundos e religar
13. Repita o passo 3 a 8 porém, substitua o 1 pelo 0 (voltando ao normal).
14.sua impressora deve voltar ao normal.Este problema é ocasionado por oscilação de energia.
Mar 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Tutoreal recovery con discos
There is a good tutorial here but in English. Maybe use google translate to help you if problems
http://www.pctechbytes.com/hp/hp-recovery
translation from google
No inserte ning?n disco en el HP Pavilion antes de comenzar.Desconecte todos los perif?ricos y dispositivos internos no preinstalado en el PC, excepto el monitor, teclado y rat?n.
Encienda el ordenador y pulse la tecla F1 cuando la pantalla del logotipo aparece por primera vez.
Pulse la tecla de flecha derecha hasta que de inicio se destaca.
Pulse la tecla de flecha abajo hasta Boot Device Priority se destaca.Recuerde que el CD-ROM est? en la lista.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo y resalte la unidad de CD-ROM lista.
Pulse el signo m?s (+) hasta que el CD-ROM est? en la parte superior de la lista.
Inserte el primer disco de recuperaci?n en la unidad de CD-ROM.
Pulse el bot?n ENTER para guardar los ajustes y salir. Una pantalla de recuperaci?n parece.
Lea y responda a cada pantalla de recuperaci?n que aparece. Al cambiar los discos, no
pulse el bot?n OK. En su lugar, esperar a que la unidad para leer el disco y que autom?ticamente continuar la recuperaci?n.
Despu?s de la recuperaci?n es completa, restablecer la prioridad de CD-ROM de arranque del dispositivo a su configuraci?n original, de la siguiente manera:
Utilice las teclas de flecha para seleccionar Boot Device Priority en el men? de arranque.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo para resaltar la unidad de CD-ROM.
Pulse el signo menos (-) hasta que el CD-ROM se encuentra en su ubicaci?n original.
Reinicie el equipo.
Despu?s de la recuperaci?n del sistema se ha completado, y el equipo se inicia correctamente, actualice el software de la siguiente manera:
Actualizaci?n de las definiciones de virus del sistema.
Obtenga las ?ltimas actualizaciones cr?ticas del sistema con Windows Update de Microsoft.
Actualice el software de HP en el sistema.
Mar 02, 2011 | HP Media Center 864N PC Desktop
Gostaria de instalar o software de driver do dispositivo
Já tentou usar o cd do dispositivo ou então no site do fabricante. Se for daqueles tipos Plug and Play ele automaticamente irá pedir o CD na primeira vez que você plugar. Se não aparecer, instale com o CD do dispositivo:
1- Geralmente ao colocar o CD, aparece uma caixinha com passos a serem seguidos do tipo próximo ou next;
2-Você pode ir apertando nos botões proximo(ou next) sem precisar alterar nada pois o padrão já instala certinho, ou se quiser pode alterar algumas coisas durante esse processo de instalação, a sua escolha ;
3- No final aparecerá que o processo foi concluído com sucesso, se não mande a mensagem para cá de erro;
4- Caso conclua com sucesso, verifique se o dispositivo foi instalado ao acessar o gerenciador de dispositivos: Painel de controle-->Gerenciador de Dispositivos;
4.1- Ou então por meio do atalho devmgmt.msc, no executar (acesso por meio das teclas windows+R);
5-Depois tente colocar o dispositivo na máquina.
Estas instruções servem apenas se o sistema for uma das versões do windows.
Mar 01, 2011 | Computers & Internet
Como puedo volver a registrar el tel si ya estaba en uso pero se borro el nip que ya tenia
primero tienes que presionar la tecla de registro/localizacion que se encuentra en la base por aproximadamente 3 segundos como minimo, luego la sueltas y le das en menu OK, luego configuracion OK, auriculas OK, Reg, auricular OK, y ahi te pide el PIN, son 0000 (cuatro ceros) OK, y eso es todo, tarda un minito o menos en registrarse, si tienes mas de un telefono, con cada uno de ellos tienes que hacer el mismo procedimiento y eso es todo, espero aun te sirva :)
Jan 02, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Meu telefone perdeu todas as funções gostaria de rest, ou não sei se da pra formatar ou fazer o bot que nem o pc. Não sei mais que faço.
Alo grande.
Em primeiro lugar, eu so formatei ate agora Nokia 6600 e nokia N73 com os mesmos codigos.
Mas tu podes usar o mesmo codigo para alguns outros telemoveis.
Faca o seguinte Apos carregar bem o cellurar.
1 _ desliga o celular
2 _ volta a ligar o celular.( em seguida pressione logo nas seguintes teclas: Verde de atender, tecla 3, e tecla ASTERIX *. tudo ao mesmo tempo...) ate sair um sinal k seu celular esta ser formatado.
Se nao der, digite os seguintes codigos.. *#7780# ou *#7370#
Boa sorte
Nov 25, 2010 | Computers & Internet
2005 Honda NX4 Falcon sistema de tarifa??o
Oi, Barracuda_ga antes de testar qualquer componente el?trico no Sistema de carregamento ? "IMPERATIVO" que voc? tenha uma bateria totalmente carregada de 12,5 volts ou mais e que possa passar um test "LOAD" adequado, se necess?rio, voc? pode ter uma leitura preliminar de 12,5 volts ou mais mas pouco ou zero de amperagem, a bateria est? com defeito e deve ser substitu?da. As baterias tipo AGM caem nesse cen?rio mais do que as baterias de chumbo-?cido.
1. Verifique os terminais da bateria para danos ou corros?o, verifique se os cabos da bateria est?o "BOTH" para conectores soltos, corro?dos ou quebrados, "INSIDE" e fora do chicote de fios, execute o test do wiggle do conector e verifique os cabos com um ohm?metro, se necess?rio.
2. Para verificar o regulador, desconecte-o do estator. Fa?a uma luz de test e prenda-a no terminal negativo da bateria e, em seguida, toque primeiro um pino e depois o outro no plugue que vai para o regulador. Se voc? conseguir a menor quantidade de luz da luz de test, o regulador ? torrado. Para fazer isso com um medidor: chumbo preto na terra da bateria, chumbo vermelho para cada pino no plugue, comece com a escala de voltagem maior do que 12vdc e mova a escala de tens?o para baixo em etapas para cada pino. Qualquer tens?o ? um regulador ruim.
3. Na outra parte do plugue do regulador desconectado. Defina o mult?metro para a escala Ohms x1 e mida a resist?ncia entre os pinos do estator. Voc? deve ler algo em torno de 0,1 a 0,2 ohms para um sistema de 32 amp.
4. Em seguida, verifique a continuidade entre cada pino no plugue e moldura / ch?o do motor. A agulha do medidor n?o deve se mover (resist?ncia infinita) (os digitais mostrar?o resist?ncia infinita) se a agulha do medidor se mover (indicando continuidade) (os digitais mostrar?o alguma resist?ncia), verifique com muito cuidado. Se o medidor ainda mostrar continuidade ao solo, o estator est? em curto (mau).
5. Ajuste o medidor para ler volts A / C superiores a 30 volts (a configura??o da escala para a tens?o deve sempre ser maior do que a maior tens?o que voc? espera ou voc? pode fritar o medidor). Inicie a bicicleta e mude de um pino para o outro no plugue (N?O atravesse as sondas do mult?metro! - toque-os um para o outro). Voc? deve ler aproximadamente 16-20 vac por 1.000 rpm.
6. Se a bateria estiver boa no test de carga, se o estator N?O estiver em curto-circuito na terra e o estator estiver apagando a tens?o do A / C, ent?o o regulador est? ruim (provavelmente mesmo se for passado o passo 2)
Para obter mais informa??es sobre sua pergunta e downloads valiosos "GR?TIS" que voc? precisar? para visualizar ou imprimir, clique nos links azuis abaixo. Boa sorte e tenha um dia maravilhoso. http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
DOWNLOAD NX 4 NX4 Falcon Service Repair Workshop Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
http://www.casasandin.com/manuales/honda/NX4%20FALCON%2000%20A%2002.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 29, 2010 | 2005 Honda NX4 Falcon
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
We have searched all the codes and the quick find for codes and nothing worked. The television is Magnavox. the remote is RCR4258 large button iniversal remote. We tried to program the cable box also and...
primero que nada buenos dias acontinuacion le dare una solucion a su problema: oprima y mantenga oprimida la tecla del aparato ya sea (tv,vcr,dvd,sat,cab) que desea programar , la tecla on-off se enciende y queda encendida .
con la tecla del aparato oprimida apriete y mantenga apretada la tecla on-off . la tecla on-off se apaga
despues de mantener 3 segundos oprimidas ambas teclas , la tecla on-off vuelve a encender sulete las dos teclas , la tecla on-off se queda encendida.
oprima y suelte la tecla {play} y espere 5 segundos si su aparato se apaga. si no se apaga siga oprimiendo la tecla {play} cada 5 segundos hasta que el aparato se apague .
apagandose su aparato oprima y suelte la tecla {reverse} y espere 2 segundos para ver si su aparato se enciende . si su aparato no responde siga oprimiendo la tecla {reverse} cada 2 segundos , hasta que su aparato vuelva a encenderse oprima la tecla {stop} para que quede programado el codigo correcto bueno espero y te sirva de algo mi comentario
Apr 12, 2008 | Televison & Video
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
128 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
