Question about Eureka Enviro Steamer 310 Stick Vacuum
Orange light comes when it is full
I went to add water and the cap shot off and sprayed hot water and steam all over me? How do I clean it out because I think it is clogged with calcium deposits.
  • Zenobia May 28, 2008
    I have a Kenwood 5000 steam mop thinking it would be easier to fill. I've found it doesn't work like the older model....The orange light comes on when I fill the top and NO steam comes into the mop head at all. I've checked the lock and unlock and it still doesn't work...
Steam xpress homewell
Marg:
If you have been using tap water, your steamer is probably clogged with calcium or lime. I would pour some CLR (Calcium, Lime and Rust remover) into it and let it sit for a few hours. CLR can be bought at Home Depot or Lowe's.
Jul 03, 2014 | Vacuums
Why is the spray always clogged?
water too hard causes calcium deposits. you can buy softener pellets for steam machines. using battery (demin) water will help prevent it
Feb 12, 2013 | Bissell 1425 Little Green ProHeat Handheld...
Can I use tap water with the S3101WT model
Yes, you can use tap water - either hot or cold.
It's recommended that you fill with clean cold water, but if you fill it with hot water, it will generate steam faster from startup. The most important thing is not to overfill it beyond the MAX mark on the tank.
Mar 07, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My handheld hot shot pressure is not as forceful as it use to be. How do I unclog or clean it. or how do you fix it?
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
1. You may use VINIGAR with HOT water to flush out the calcium bulidup in the sprayer.
2. Before using anything stronger, consult your manual to ensure you will not damage the device
Jan 10, 2011 | Eureka 350A Handheld Steam Vacuum
My Sunbeam Pro Stream II Teflon shot and spray iron consistently spits water as I try to iron. I don't overfill it and the temperature and steam dials are set correctly. help!
How old is the steam iron?
And what type of water have you been using in it during its life?
The reason I ask, is that my Wife's was doing this, and we have fairly 'hard' water,
and she was using water directly from the tap.
After a year or so of this 'hard' water, calcium and minerals build up in the heating chamber in the iron-- Also passageways get clogged, and instead of smooth flowing steam, you get build-up of pressure, and then sputtering and spurting take place, as the clogged passageways try to pass the steam to where it needs to be.
Tell us more--
Mack B
Dec 28, 2010 | Vacuums
Steam coming out but no water is being distribued for the steam to dry it
If you have used it a lot and you have hard water... the calcium deposits will clog the water dispenser. That's what happened to mine. I cleaned it out with white vinegar and it started working fine. It's simply something clogged in the water dispenser.
Zashiban
Jun 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Shark handheld steamer heats up but does not spray
Try rinsing it out with CLR, it gets rid of calcium, lime and rust deposits i heard its very good.
Jul 10, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Eureka Enviro Steamer 310 Stick Vacuum Logo
95 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
