Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Having problem getting fuel to carb on JD LA 105 lawn tractor with B&S 19.5 gas engine. I replaced fuel filter and fuel pump but gas will not flow to carb. Gas flows from filter to pump and I can pour gas in line to carb and engine will run until gas runs out of line but gas will not flow through pump. Could new pump be bad , if so how can I check it out?
  • 272 Answers
SOURCE: JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
Posted on May 10, 2009
  • 6 Answers
SOURCE: not getting gas to the carb
There may a screen in the gas tank that is plugged. Drain gas from tank...inspect with flashlight. Clean screen with aresol carb cleaner and gently blow low pressure compressed air backwards through the fitting
Posted on Jun 09, 2009
  • 148 Answers
SOURCE: Kohler 22 HP Engine 2 cyl craftsman lawn tractor
Have you pulled the filter out to see if it's clogged? The easiest way is to remove from the system and blow through the filter. If you can blow through easily then you might have a bad fuel pump.
Mike
Posted on Aug 24, 2009
mowerman1857
  • 389 Answers
SOURCE: 20 hp 42
Check to see if your fuel solenoid on the bottom of the carburetor is working. To do this, turn the key on and off a couple of times and listen for a "clicking" sound or with someone else turning the key, hold the solenoid between your thumb and fingers and see if you "feel" it clicking on and off
Posted on Sep 20, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
24 hp Craftsman lawn tractor will not start; doesn't appear to be getting gas in the carb. It is pumping through the fuel pump.
hi Vet68652, I have to agree with tomicamel, it does sound like a clogged fuel filter there is nothing else between the pump and the carb.... unless the line is clogged,
Mar 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Kawasaki 19 hp not getting gas
This engine will probably have an in line filter and a black plstic fuel pump bplted to the side of the engine, rplace the in line filter first, if no better pull the fuel hose off the carb and crank the engine, there should be a staedy flow of fuel, if not check the pipe connections on the pump are good ( it is a vacume pump, it taks a pulse from the engine to work a diaphram ) if connections are good and no fuel flow, replace the pump, there will also be an anti fire solinoid on the bottom of the carb, to check this component remove , switch the ignition on, the jet inside should sink into the housing.
Jul 07, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Not getting gas to the carb
Jun 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Cant get gas from tank to engine
check to see if there is a fuel pump diaphram first and rebuild or replace it , otherwise you arent getting any vacuuum in the carb to draw the fuel in.
Apr 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
316 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
