Audiobahn A2200HCQ (not available on the list to select from)
I need to find replacement screws for the two large power wires. I found good fits for the other five smaller ones. Size is close to 5/16 inch, and between 8 and 10 mm, but nothing I tried fits quite right. Any suggestions on what the size might be or where to find them?
The smaller screws should have been 5mm dia with a 0.8mm thread pitch. The larger ones are probably 8mm dia. with a 1.25mm thread pitch.
Is 5/16 too large or too small? If 5/16 is too large, the screw is probably 7mm.
Do you have one of the original B+/ground screws? If so, it should be easy to measure it and get the correct size.
