Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Bottom fridge compartment is warm (60deg). Top freezer working good. Is cold control unit replaceable by customer?
  • sunnymack Aug 06, 2010
    Thanks much for the advice. We tried the simplest fix first and had a neighbor unplug the machine for about 30 hours. As you correctly guessed, the return ducts were apparantly iced up and needed to melt out. As soon as it was plugged back in, all worked well. The unit is in a cabin about 100 miles away, off a 4-wheel road, so your help saved us a ton of aggrevation. This is my first time using the site, but you have won a supporter! I have already told my friends about it.
    President:
  • 1,218 Answers
Good day,
If the machine runs then it is not the cold control. You need to remove the rear panel in the freezer compartment and on that model usually means removing the vertical chute running up the center of the back panel and as well removing the fan motor.
I assume the fan motor is running. if not, that is your problem.
Before doing any of this make sure the light goes out when you close the door. You can see it go off just before the door closes.
That would produce enough heat to cause the fresh food section to run warm.Check that chute you removed to see if ice built up in it, as well as the the hole it discharges air into the fridge section.
Once you remove the rear panel, inspect the coil for ice build up.
If the coil is iced it will need to be defrosted.
If the coil is badly iced or frosted up, then you have an auto defrost problem. The defrost system is made up of 3 parts. The timer, which is located behind the cold control, and then back in the freezer compartment the main heater which runs along the bottom of the cooling coil or the defrost thermostat that is a small 1" disk which is clipped to the top of the coil on the right side although somwhat hidden behind some styrofoam.
In most cases it is either the timer or the defrost thermostat that has failed.
A good tutorial follows at the end of this post.
If all of the above proves to be O.K. then on Frigidaires, they have a tendency to ice up the return ducts. You can't see them, and you can't defrost them. The only way is to unplug the machine for 24 hours and let it melt out on it's own.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Aug 03, 2010
  • John Hall Aug 07, 2010
    Good day,
    I'm glad it's working, however, it unfortunetely should have been the last step, as I had outlined. If it repeats shortly, then there is a good chance it is the defrost system not working properly.
    But, if needed, just post back.
    jACK
    Problem Solver:
  • 17 Answers
It may not be your cold colntrol. it is more likely the defrost terminator or the heating element (both located in the freezer section) or the defrost timer (located in the refrigerator section). you most likely have an ice buil-up on the evaporator coil that is preventing proper circulation of air accross the coil and into the refrigerator section.
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge too warm
I had a similar problem several months ago.
1) Top freezer compartment is getting TOO cold. The ice gets so thick, it blocks the channels of cool air from the freezer down to the fridge compartment (hence fridge too warm)
SOLUTION: Turn fridge/freezer off to fully defrost, then turn back on.
NB: This might only be a temporary fix, and you will find in a few months time the same thing happens?
2) In my case, I required a replacement of the "controller" board which fixed the defrosting problem of my freezer compartment.
Good luck.
Oct 26, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
124 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
