Question about RCA HD52W59 HDTV Projection Television
RCA 52w59 blue and yellow hue or Shadows on various locations of the screen. I do not have the normal issue of a convergence problem the FL321 fuse is okay and the fly-back solder joints are fine. I can get the auto convergence to come up or manual setup as well but they do not solve the problem. Is there another known issue I may have over looked?
  • RCA Master
  • 8,617 Answers
The convergence power supply is usually the cause if more than one color is out. If only one color is out then the convergence board would be most likliest. Boards are available from www.tvrepairworld.com
Posted on Aug 04, 2010
My picture tube looked bowed and in 3D. What is the problem?
change the convergence fuse located next to the flyback its red and shaped like a rectangle ref fl321 number . part number is 259213 400ma 125v you can order at ebay or from newark com for 51 cent there part number is 67K2174. its the same fuse.
Sep 11, 2010 | RCA HD52W59 HDTV Projection Television
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
Rca 46 in pip
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 09, 2008 | RCA P46924 46" Rear Projection Television
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
