Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Can you tell me how to order the set screws that make it able to skip days?
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
Lost manuel....how do I set the day and time....
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
Mar 29, 2011 | Radio Shack 3808 Digital Answering Machine
My paragon timing motors model 1015-00RSB are not timing as desired,how can i or guide me on how to programme and make schedule adjustments on it? Please help me
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
The Paragon 1015 timer is a 24-hour timer.
The tripper pins or tabs are built into the timer dial.
This timer has NO and NC terminals.
NO NC terminals mean the timer can control two different circuits.
One circuit would be ON when the other circuit is OFF.
When the timer turns on, the circuits change so now one circuit is OFF and the other circuit is ON.
If you have just one circuit, then the following instructions will help you.
If your timer controls two circuits, you can add a comment and I can help further.
OK, your timer controls one circuit.
Locate the tabs on the timer dial.
Push down all the tabs.
Now lift all the tabs for the times you want your Load to turn ON
So if you want the Load to turn ON from 7pm to 5am, then lift all the tabs between those times.
Now when the timer dial rotates, the tripper tabs operate an on-off lever that turns the Load ON and OFF.
Set current time of day
The timer has to be set to current time.
For example it's 6pm.
Grasp and rotate dial until 6pm lines up with the stationary red pointer
Skipper wheel:
The 1015 series has a skipper wheel that lets you skip days of the week.
On these days the timer program will not turn the Load ON or OFF
So if your regular schedule is ON from 7pm to 5am, then the Load will remain OFF for those times.
Set skipper wheel:
Locate day to be skipped on the small dial.
Raise the set screws for the days you want to skip
Raise set screw until it is tight, but do not force
After a power failure, current time of day has to be reset.
If you need more help, add a comment and I will assist.
Nov 03, 2010 | Paragon 1015-00RS Indoor Multi Operation...
I cannot change the time or date that the message comes in? When a message is received the day and time are not correct, how do I change that setting?
1. Press menu once and answering machine announces "Time" and current time. The answering machine displays (1) through (7) indicating the day of week.
2. Press skip/ff or repeat/rew to until correct day is announced.
3.Press set/ringer to select the day.
4 press skip/ff or repeat/rew until correct hour from 1 to 12 is heard.
5. Press set/ringer to select the minute/
6. press skip/ff or repeat/rew until correct minute from is announced.
7. Press to set/ringer to select the minute.
8. Press skip/ff or repeat/rew for A.M. or P.M.
9. Press set/ringer to store your am or pm selection.
Thats all it takes so you shouldn't have any more problems like that, but if you do I will be glad to help.
Jul 09, 2010 | Uniden Cordless Phone exai398i
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Skips Through Songs without Playing them
Do you have it set on SHUFFLE? That may be the problem - SHUFFLE will play songs randomly instead of in order.
You can tell if it is in SHUFFLE mode when you look at the screen between the battery ICON and the PLAY ICON -
Press the top right button until there is nothing between those two icons.
Mar 06, 2009 | iRiver H320 MP3 Player
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
Then release the button.
7 Press and release C. The new day
and time are announced.
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Need to change the date and time
message is received. Press "Play/Stop" to exit
1 Press and hold "Clock" until the
"Memo/Repeat" or "ANNC/SKIP" until the
release the button.
3 Press and release "Clock". The current
"Memo/Repeat"or "ANNC/SKIP" until the
release the button.
5 Press and release "CLOCK". The current
down "Memo/Repeat" or "ANNC/SKIP" until the
7 Press and release "CLOCK". The new day
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
At&T 1738 digital answering machine -- how to set time
Press and hold C until day of the week is announced. It will say Monday. If you don't want monday use annc/skip to go to the next day. When you get to the day you want hit set. This will save that day of the week for you. Then it will annouce hour, select the hour by doing the same thing and after you have the hour press the set button. Do this for the minutes too. Lastly is the year, if you've went to 2027 and it won't loop back to 2007 say, you can usually unplug it and it will reset the year back to the factory setting.
Oct 23, 2008 | AT&T 1738 Digital Answering Machine
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
