Question about Gestetner DSc332 Copier
Gestetner DSC332 SC393-02
Any one know what that is or what machine this crosses over too. Savin /Ricoh?
  • terrycmi Aug 20, 2008
    I have a aficio 2232c copier.
    the code is sc393-02.
    i removed the yellow cartridge and replaced it. What exactly is the developer unit"? Is it the cartridge? Or the roller unit inside?
    Do i need to buy or clean something to make it work?
    terrycmi@aol.com
  • Gestetner Expert
  • 287 Answers
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
Posted on Apr 27, 2008
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 06, 2011 | Gestetner A045 Wide Format Copier
Do You have anyone in the ocala florida area that services gestetner cpoy machines?
Look for a copier dealer or service center that is listed as repairing Ricoh, Savin or Gestetner. They are all the same machines. In other words your Gestetner copier is made by Ricoh and Ricoh Dealers are far more common and easy to find than Gestetner. If you need to know the exact model then just reply with your Gestetner Model number and I can tell you what the Ricoh equivalent number is.
Hope this helps.
WheatlandServices
Dec 08, 2010 | Gestetner Copier
Savin 3030
"user tools"
"System settings"
"interface settings"
Press the "ip address" button and set.
The model cross references to a Ricoh MP C3000 (Ricoh builds all Savin machines). You can get all the manuals here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mpc25/mpc25en.htm
Mar 12, 2009 | Ricoh Office Equipment & Supplies
NEED SERVICE MANUAL FOR RICOH FT5733
You can go to; www.user-manuals.com . They have it for sale $14.99.
You could also go to; www.gestetnerusa.com and cross check the model, they may have a free download PDF.
Ricoh is the parent company with Savin, Lanier and Gestetner under them.
Dec 31, 2008 | Ricoh Office Equipment & Supplies
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
Mar 02, 2008 | Gestetner DSc332 Copier
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
698 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
