Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch mower cuts uneven, what is the problem?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Posted on Aug 04, 2010
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
Pulled the front two pins loosend the bolts still cuts somewhat uneven
check blade alignment.raise deck[motor off] and look underneath,and turn blades by hand and see if they are runing true
Jun 11, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,211 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
