I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it work?
    Guru:
  • 1,082 Answers
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Posted on Aug 03, 2010
  • amberleefish Jan 12, 2011
    YOU NEED TO PUT SOMETHING FOR IF YOU HAVE 4 DIFFRENT SETUPS,AND WHICH ONE TO CLICK!
I have windows xp with Firefox and I installed Nancy Drew Danger by Design, but when I try and play it a window pops up telling me to insert disc 1 and press ok. I do that but it won't do anything but...
Hi
I'll start with a few issues that might or might not be relevant but do need to be considered and eliminated.
I will assume that this game is in the PC Format required for use with computers, rather than Games Consoles and is compatible with Windows XP and is not an older program designed for use with older Operating Systems such as Windows 95, 98, ME or 2000 or for only other, newer Operating Systems such as Windows Vista, Windows 7, Linux or Mac OSX. I will also assume it is stored on a genuine original disc rather than a copy of one.
It is likely that it is one of a certain type of games which can only be played with the Disc in the computer. The original discs of such games can rarely be copied successfully and when copied discs are used, they tend to produce exactly the same results you describe.
Instead of inserting the disc when requested, leave the disc in the computer and start the game with disc already inside, ready for XP to immediately recognise and access it without any delay.
If this doesn't solve the problem > uninstall the game and all its components completely from the computer > start > control panel > add or remove programs >click once to highlight the game's program > Uninstall > yes > OK > shut down > restart the computer > check that the read surface of the disc is clean and unscratched, wiping the read surface of the disc in a gentle, slow, circular motion, using a slightly damp paper towel, if necessary > install the program again carefully and methodically, looking out for tick box options you may have missed during previous installations, especially any alternative option that allows you to choose whether to access the game's files from the disc during play or, alternatively, to do so from the computer - if so, choose computer > Restart the computer > leaving the disc inside the computer, test the game again > to remove the last doubt, test the game without the disc in the computer.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This gives Answerers, like me, the opportunity to better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or Add a Comment to this Question.
Thanks for using FixYa.
Sep 04, 2011 | Computers & Internet
Hi, The game, Nancy Drew: Danger by design, doesn't work in my laptop. Every time I try to play the game, the screen freezes but I can hear the music at the back ground. All the other Nancy drew games...
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
Jul 11, 2011 | Her Interactive Nancy Drew: Danger by...
I installed the game, and when I put the disc in to play it, the main menu isn't even shown. The screen that says "Her" with the magnifying glass doesn't do anything, it just freezes. I can...
Here are a couple of ideas- I have played many of the Nancy Drew games, so hopefully something here will help you. First thing I would try is to not put the disc in to play. I think that you do not need the disc to actually be in the computer on this game. Some of the games will load the game twice if you have the disc in and then you can't play it at all. Another words that computer tries to load the disc and the game already installed, and it doesn't work well. So you might want to try that first. Also there is the uninstall and reinstall to try next. Did you check that you disc drive is compatible? If you are playing on an older computer, check that you have a dvd drive-newer computers do. Also do you have enough ram and a fast enough processor? If you look on the package, it will tell you the game requirements, another words what type of set up you need in order to run the game. I would guess that you do have the right requirements, and one of the first two suggestions will fix it. Good luck!
Dec 28, 2010 | Her Interactive Nancy Drew: Danger by...
Hi, I tried installing nancy drew shadow at the waters edge but when i put the disc in it has like a window show up with all of the games files and i click install wizard to install so i go through all...
You can get a free installation of direct X off the program in most Nancy Drew games, but if that does not work you can get a free direct x install off the internet.
Dec 26, 2010 | Her Interactive Nancy Drew: Shadow At The...
Message in a haunted masion cannot load to machine, have Windows 7.
there are some nancy drew games that wont work on windows 7, the first 10 wont work or wont work right. The Herinteractive.com ( the company) is makeing new versions of the older games so people with windows 7 can play the older games. for now, you will have to wait till the new ones come out.
Sep 14, 2010 | Her Interactive Nancy Drew: Message in a...
Im trying to play nancy drew secrets can kill, and its all instulled. however when i click on the shortcut to play the game i get a black screen with a box in the middle that says ''nancy drew is unable to...
if you desperately want to play nancy drews that have that problem, there is a way but this way youl have no sound but the game will still play.
Go into the directory where you installed the game and then o into the game.ini file. it should open in a notepad.
go to sound system is active=1.
change the 1 into a 0. then enjoy. the game may have no sound but its still the game ayyy
nd dont try and change the volume or else the game shut down.
Aug 31, 2009 | Her Interactive Nancy Drew Secrets Can...
I get the following error message trying to load Nancy Drew Danger on Deception Island... Incorrect path to ini file
You create a new folder, name it something like "deception" and save it. Then insert the disk and begin install, when it asks you where you'd like to install it, click browse, and install it in the folder you created previously. It won't work if you just install it in the recomended folder...
Apr 28, 2009 | Computers & Internet
Incorrect path to INI file
install the game and when it gets to the install on C:\nancy drew click browse and choose program files then install there the game will then run but requires the cd to be in the drive
Jan 01, 2009 | Her Interactive Nancy Drew: The Secret of...
Computers & Internet Logo
1,082 people viewed this question
Alun Cox
David Payne
David Payne
