Question about Boating
How do i replace an impeller on a 5.7 merccruiser inboard /outboard engine
    Champion:
  • 243 Answers
There Is a Impeller On The Sea Water Intake Side Driven By A Fan Belt At Front Of Engine ,
Remove Cover Pull Out Impeller Check Key Fit New Impeller And Gasket
Posted on Mar 30, 2013
5 Suggested Answers
  • 86 Answers
SOURCE: how to replace impeller in a 1959 evinrude
Put engine in fwd gear. Then disconnect the shift linkage. Remove the bolts that hold the gearcase on and slide gearcase off of the tower. Remove the 4 bolts or screws in the waterpump housing and lift the housong off. Replace the impeller and reassemble in reverse order. Make sure that you get the water tube lined back up and you can twist the prop to line the splines back up in the powerhead.
Posted on Aug 09, 2009
  • 5687 Answers
SOURCE: 1989 galaxie boat. inboard/outboard 4.3l stiff steering
The first thing I would do is disconnect the steering at the transom. You want to find out if the problem is in the helm(steering wheel) or in the inboard/outboard pivots.
When you turn the wheel after the disconnect, it should not be hard. There is a set screw in the steering assembly either above or below the dash. There should be enough tension so the boat does not wander but not enough to be terrible to steer.
Next go to the outdrive. Without the steering connected, the outdrive should move with minimum resisitance in either direction. There are pivot points on top and bottom that should have marine grease at the start of each season.
You have a 21 year old boat. The driveshaft in the Inboard/Outboard should be greased every 2 to 3 seasons and the watertight bellows can be inspected at that time.
Now if the steering is even worse under power, you need to adjust the fin that drops down behind the prop. This part controls Torque steer so the outdrive is not trying to turn on you and wants to stay straight. If you do not have a problem leave it alone.
You can get an estimate for the driveshaft service and greasing U-joints and inspecting the bellows. They should grease the pivot points then too. I am told its about a 2 hour job. In my area its 60-70 an hour.
Posted on Apr 13, 2010
SOURCE: Mercruiser 5.7 litre inboard engine Impeller fault
i have a 5.7 v8 4brl in my boat with top water exhaust and my valve cover filter tubes are sendig excessive moisture into my carb . why
Posted on Apr 20, 2010
  • 11 Answers
SOURCE: replaced impeller on a 150 yahmaha outboard, cant get it to slide all the way back in
Get someone to turn the flywheel slowly while you keep upword pressure.This will allow the splines on the shaft and flywheel to mesh.Or turn prop if box is in gear.
Posted on Nov 26, 2011
MY classic 1976 Austin mini tends to over heat when outside temp is over 35c thermostat replaced with a safari one Radiator good WHY???
Maybe the engine cooling pump not work well?
If use flexible rubber impeller in the pump,check the vanes are leak or broken down?
We supply full range raw water pump impellers for outboard and inboard.Our website www.flexible-impeller.com
Normally we can delivery out by FedEx/UPS in 3~5days arrive customer's hand.I hope which can help you:-)
Best regards from Lindong
Jabsco Johnson Sherwood Water Pump Flexible Impellers Outboard Inboard...
Jun 29, 2017 | Mini Cars & Trucks
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
How to winterize an inboard/outboard boat motor
Flush the motor with fresh water, drain and refill drive gear with fresh oil , the same with the motor, remove spark plugs inject 10 ml of engine oil into each cylinder, turn engine over by hand so cylinder walls are coated, refit plugs. I then like to spray every thing WD 40. Remove the battery if you have a trickle charger connect it.
Oct 20, 2014 | Boating
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
What are the types of engines for boats?
The main types of engines when it comes to boats are: steam engine, gas turbine, diesel engine, steam turbine, and gasoline engine.
Jan 10, 2013 | Boating
How to back the brakes off on a 2001 pontiac grand am so I can replace with new brake pads
Welcome to Fixya
Please see procediure below:
  • 1
    Disconnect the negative battery cable. Using a syringe, turkey baster or similar tool, drain two third of the brake fluid from the master cylinder. Raise the Grand AM up and secure it on jackstands. Remove the wheel assembly.
  • 2
    Remove the caliper from the steering knuckle. Using mechanic's wire suspend the caliper from the frame of the vehicle. Avoid having the caliper dangle or hang from the brake hose or it will result in the brake line being damaged. Remove both the inboard and outboard brake pads. To unseat the clip tilt the inboard pad out at the top.
  • 3
    Remove the outboard pad. Release the mounting dowel from the hole in the caliper by pushing the outside pad in an inward motion. Pull the inboard pad outward to remove it from the caliper.
  • 4
    Install the inboard pad. Make sure that the spring clip engages in the caliper position. Install the outboard pad over the caliper end. Make sure that the mounting dowels snap into the mounting holes in the caliper. Install the caliper over the rotor onto steering knuckle.
  • 5
    Insert the caliper mounting bolts and sleeves. Torque the bolts to 23-ft. lbs. Reconnect the wheel assembly. Add brake fluid. Reconnect the negative battery cable to the battery.
  • 6
    Start the engine and pump the brakes 3 to 4 times to seat the brake pads. Test drive the vehicle at slow to moderate speeds to ensure that the maintenance was performed correctly.
  • Thank you for using FIxya!
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    May 08, 2011 | Pontiac Grand Am Cars & Trucks
    Boating Logo
    104 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
