Question about Lexmark Wheelwriter 5 Series II Typewriter
Each time you depress a key it makes a chirping noise
  • Lexmark Master
  • 3,594 Answers
Do things print and act normally? If so try code "S".
If there are other problems please be clearer.
DickyO
Posted on Aug 03, 2010
1999 ford expedition make noise when idle but stop when pickup speed. make a chirping sound when idle .i check pulleys & belt (ok) disconnect belt but still make chirping sound
Might be your water pump. Check for drips of antifreeze
Usually the bottom of the pump has a weep hole and the 1st sign besides the noise is antifreeze dripping from the weep hole
Jan 08, 2011 | 1999 Ford Expedition
I left the lights oon now i need a jump start but dont have the alrm key it goes off edvery time i attempt to start it but it wont start
Reach under the dash and depress the valet switch. Listen for the alarm off chirp. Then start the car.
Jul 12, 2010 | Cars & Trucks
It makes a chirping noise all the time
Chipping can be caused from a bad bearing that needs to be replaced or lubricated. It could be inside the alternator. power steering pump, idler pulley, Whater pump, AC compressor, and so on.
Use a long handle such as a broom stick and place the stick to each item that is belt driven. Place it at a secure place such as the housing so the stick does not get near the belt. As the engine is running place your ear at the other end of the stick. This works as a Stethoscope same as a doctor uses. The chirpping will be hear the loudest at one of the belt drive accessories during your testing
May 18, 2010 | 1996 Jeep Grand Cherokee
Abs brakes chirping noise, when pedal depressed,
worn out brake pads and slightly warped rotors. Most brake pads have small steel tabs that touch the rotor at a 90 degree angle when it is time for replacement. if you keep driving on the worn pads, it will stop chirping but that just means the tabs (also called wear indicators) have broken off and repair is about to get very pricey.
Feb 28, 2010 | 2001 Mitsubishi Montero
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
97 Golf that makes a chirping noise
have you checked the CV joints, there only good for approx. 100,000 kms.
Sep 01, 2009 | 1997 Volkswagen Golf
Chirping noise that is not coming from belts
Your fan belt is worn, its time to replace it.
Aug 29, 2009 | 2000 Mercury Sable
Lexmark Wheelwriter 5 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
