Question about HP Compaq nx6110 PC Laptop
My wireless button doesn't seem to be working....i press it and nothing happens...i already installed all of the drivers from the hp site but still no result:((
  • 643 Answers
Im not sure how long ago your wireless stopped working..
But my first suggestion would be to do a system restore back to before the wireless driver stopped working.
You can do a system restore via , start, all programs, accessories, system tools, system restore.
Posted on Aug 03, 2010
Compaq SG3340IL WINDOWS XP LAN DRIVER
Checking the HP/Compaq site, the Compaq SG3340IL uses Realtek Gigabit LAN.
You can download the needed driver HERE.
Oct 10, 2011 | Compaq Presario 700 470024-192 Notebook
On the HP ProBook 4720s laptop, there's a button with a wifi symbol on it and a small led on the up-right corner of the key. When I got the laptop it was light blue. Seems now it's always orange....
Try enabling windows zero configuration, and using the windows wireless connection manager.
There should be an option in the ralink program to enable the feature, after that push the button and click refresh wireless networks or the refresh button.
If nothing happens or no wireless network are found try it again.
If nothing happens the second time your wireless card needs to be replaced you can consult your service manual at the hp support site for more info
Jun 15, 2011 | Computers & Internet
Hi, I have a HP Compaq nx6110 with Broadcom wireless adapter, and I have a Wireless problem. I've recently reinstalled my OS, it's a Win XP SP3, and ever since my wireless adapter wont start, it...
  1. Make sure to press the WiFi button on your notebook. You should see a blue light if your WiFi adapter is on.
  2. If that doesn't work, download and install the latest version of the wireless adapter driver.
    http://bit.ly/lrDIcL
May 07, 2011 | Computers & Internet
Compaq presario m2000 blue wireless light doesn't
You should have re-installed the Driver for the Wireless Card, you can do that by going to Control Panel, than clicking on System and Maintenance, and than going to Back Up and Restore, go to Repair Windows using System Restore, you can re-install your Driver that way or go to www.hp.com and go to Support, enter your Model #, and you can re-download your Driver from there.
Jul 12, 2010 | Compaq Presario CQ60-220US PC Laptop
We have an Advent 7088 laptop and want to connect it to wireless router. We thought a wireless facility was already installed in the 7088 but when we try the wireless on/off button nothing happens. What...
Try this: I found it after doing some searching on the web.
Wireless card stops working after upgrading to Windows Vista
After upgrading to Windows Vista everything works fine apart the Marvell Wireless card, when you press the button nothing happens.
There seems to be three different ways of solving this problem (there is a fourth - don't install Vista) and I've listed them below, hopefully at least one should work for you.
The first solution is to press the wireless button while Windows Vista is loading, you have to be quick though as it only works if you press the button between the loading scrolling lines logo (after the post screen) and before the windows logo appears.
The second is to go into Device Manager, select the Marvell Wireless card and then go to Properties>Advanced>Default Adhoc Mode. Here change the Default Adhoc mode to B or G. When you confirm the change the wireless connection should become active, if it doesn't then press the wireless button and try changing the setting again.
The third method is to create a desktop shortcut to the wireless adapter. Go to [Network and Sharing Centre]>[Manage Network Connections] and then right click the wirless connection and choose Create Shortcut. You can then switch on the wireless at any time, just point at the shortcut then right click and chose Disable. Once its disabled right click on the shortcut again and choose Enable. It should then connect within 20-30 seconds.
Support site: http://www.uktsupport.co.uk/advent/laptop/7088.htm
Mar 11, 2010 | Computers & Internet
I tried the buttons but that doesnt seem to work
Are you able to view the red light on the bottom of the mouse? If not, your batteries are installed backwards. It's counterintuitive. The left batter is installed with the negative end exposed. Typically the sign displayed is what you should insert. Reverse the direction of your batteries, make sure the infrared light is visible and then click the green button on your mouse along with the connect button on your USB device.
Jan 17, 2010 | HP Wireless Optical Mouse
Enabling wireless connection on Presario R3000
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=442914
Networking Drivers And Utilities Can Be Found Under "Network-Driver"
Go to device manager (Right click my computer , properties , hardware , device manager) and check for any devices listed with a yellow ! next to them
Download and install the wireless driver or alternatively right click the device with the yellow ! and click update driver. The wizard then guides you through the steps of searching for and installing the correct wireless Lan driver.
When finished , check to see if the connection has appeared , either at the bottom near the clock or in the network connections area (access from control panel)
If yes - Problem Solved!
If no - Download the Correct wireless lan utility from the link above that corresponds with the driver you downloaded.
install the utility and load it to see if it detects any wireless points
Dec 10, 2008 | Compaq Presario R3000 Notebook
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version 1.5.0.5 of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
http://www1.medion.de/downloads/?op=search&lang=au&type=TEXT&Param=
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
I just reformatted my V4000 hp laptop, and am trying to set up my wireless. I tried to turn on my internal wireless card by pressing the wireless button, but nothing has happened. What can I do?
hi, as you came online, findout the name of the device from the device manager and search the driver in the net. down load the driver, place it on a folder and go for update the driver from device manager, show the folder, to install it from there.
if not worked let me know
Aug 25, 2008 | Computers & Internet
Useless printer f340
HP gear is troublesome all right. Sounds like the drivers and software necessary to catch the button push on the scanner is not installed or working correctly (this is separate usually from the other drivers and so forth). Try reinstalling all of the HP drivers and utilities from the latest versions on their web site.
Good luck...
Nov 13, 2007 | HP Deskjet F340 All-In-One Printer
HP Compaq nx6110 PC Laptop Logo
238 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
